RPG Posted February 1, 2016 Share Posted February 1, 2016 Does anyone have a source for the metal driveshaft boot clamps for a R1150RT? I want to replace the tie wraps with the metal clamps. thanks, RPG Link to comment
dirtrider Posted February 1, 2016 Share Posted February 1, 2016 Morning Rick BMW still lists the metal clamps for the BMW 1100RT so you might see if those will fit your 1150RT (BMW parts book lists the 1100 metal clamp sizes in milimeters, that might help you) Link to comment
RPG Posted February 1, 2016 Author Share Posted February 1, 2016 Thanks D.R. I'll check that out. Rick Link to comment
Fil Posted February 3, 2016 Share Posted February 3, 2016 As DR says, the boot clamps are still available for the 1100's, but you will need to reduce the length of the larger one that secures the boot to the drive shaft housing.I just snipped it to length, drilled a small hole for the securing screw and bent the end over. They are marked 82mm and 132mm. Here's a pic of them fitted to my 1150gs: Link to comment
