Brycelyoung Posted January 30, 2016 Share Posted January 30, 2016 Greetings! I wrote before about the "choke cable mystery." Now I'm back with an even more exciting mystery plug! Anyone know what this goes to? It is bundled with the electric plug that goes to the solenoid valve off the charcoal canister. I'm about ready to put the tank back on, but want to figure this out first. Help is appreciated! Here's a picture: Link to comment
dirtrider Posted January 31, 2016 Share Posted January 31, 2016 Evening Brycelyoung The picture is kind of blurry but that connector no doubt goes to the "CO potentiometer" The CO potentiometer is only used on non catalytic converter bikes. The U.S. bikes came in with cat converters & o2 sensors so that connector is not used on U.S. 1100 bikes. Link to comment
Brycelyoung Posted January 31, 2016 Author Share Posted January 31, 2016 Awesome! Thanks. I even forgot to tell you what bike it was, and you got. Link to comment
Christo Posted January 31, 2016 Share Posted January 31, 2016 Thank you DR! I've been wondering about that plug ever since I did the transmission work. I concluded from the grainy service manual pictures that the plug went nowhere, but that's all I had to go on. Nice to finally know what it's for. Link to comment
Selden Posted February 1, 2016 Share Posted February 1, 2016 Aren't digital cameras wonderful? I took photos before, during, and after a clutch replacement, and when I was done, that connector was sitting there, with nothing to plug into it, I started freaking out. DR's response from 4 years ago: That type of connector is a basic SENSOR connector & seldom if ever used on things other than Fueling Control or Motronic inputs. That connecter you show is for the Co Pot (used on non 02 sensor/non cat converter equipped) 1100's. On 1100's built with no 02 sensor, the correct (or lack of) CCP, & hopefully no cat to poison that connecter is plugged into a Co. Potentiometer that allows idle & just off-idle fueling mixture to be adjusted to control the idle Co. output. Link to comment
