Bud Posted January 6, 2016 Share Posted January 6, 2016 The arms on either side that go up, what are they called? Link to comment
mrzoom Posted January 6, 2016 Share Posted January 6, 2016 What vehicle?? Some manufactures call them rear strut arms or rear control arms. Hope this helps. Wait a minute, there aren't any of this on a boat. Link to comment
chrisolson Posted January 6, 2016 Share Posted January 6, 2016 On a Macpherson strut rear suspension setup like that they are normally just called control arms . Although you could add front and rear if desired. Link to comment
Rocer Posted January 6, 2016 Share Posted January 6, 2016 I believe the equivalent on my Honda Ridgeline are called "rear trailing arms". Link to comment
Joe Frickin' Friday Posted January 6, 2016 Share Posted January 6, 2016 The arms on either side that go up, what are they called? Just so we're all on the same page (no pun intended), this appears to be a top-down view, i.e. the arms that "go up" in the picture are actually horizontal with respect to the vehicle. And yes, they're control arms. Link to comment
John Bentall Posted January 6, 2016 Share Posted January 6, 2016 I used to call them radius rods, but they can also be called radius arms or torque arms. There function is to control wheel movement in a fore/aft direction- which is why they can also be called control arms. Link to comment
Highway41 Posted January 6, 2016 Share Posted January 6, 2016 The arms on either side that go up, what are they called? The arms do not go "up"; you are looking straight down at this suspension assembly so they go fore/aft. They are called various names - control arms, stabilizer links, torque arms, etc. Link to comment
Bill_Walker Posted January 6, 2016 Share Posted January 6, 2016 They might also be called trailing arms, since the wheel hubs "trail" behind them. Link to comment
elkroeger Posted January 7, 2016 Share Posted January 7, 2016 Ok, "control arms".... but why do you ask? Link to comment
Bud Posted January 7, 2016 Author Share Posted January 7, 2016 Inquiring minds want to know. A friend wanted to know and I didn't know so I got the right answer from the BMWST brain trust. Link to comment
Mister Tee Posted January 18, 2016 Share Posted January 18, 2016 So, a little bit of trivia here. 1. The vehicle in picture is facing forward in the picture-down direction. 2. Draw lines through the two respective pivot points at the wheel axle and where the steering rack attaches. 3. They will intersect at the center of the rear axle. 4. When you turn, all wheels will be perpendicular to a common point, along the extended rear axle centerline. This is why the arms are angled as such. Link to comment
