mistral Posted January 3, 2016 Share Posted January 3, 2016 I just removed my coils checking the valves. One of them had the rubber disintegrate when I removed it. Will coils off of hex heads work on a 2011. I see some of them on ebay. I figure they won't but I thought I would ask. Thanks. Ron Link to comment
Doug_Baliko Posted January 3, 2016 Share Posted January 3, 2016 They might be the same based on this chart http://www.euromotoelectrics.com/v/vspfiles/assets/images/berustickcoilsbmw71913.pdf Doug Link to comment
Danny caddyshack Noonan Posted January 3, 2016 Share Posted January 3, 2016 The fact that the rubber fell apart is interesting. Many polymers do not do well in high-voltage / ozone environments. They'll cross-link and lose plasticizer at an accelerated rate each a big factor in the falling apartedness. Wonder if you had some spark jump causing the problem. Don't forget the dielectric grease. BTW, I just replaced 8 on a 2000 Ford truck engine. Because it was a multi-hour job, I checked the coil to plug fit on each one before installation and then greased them well. What a stupid design on that era engine. Link to comment
Bernie Posted January 3, 2016 Share Posted January 3, 2016 The CamHead Bikes use a smaller spark plug then the HexHead and I believe a different ignition coil. The chart shows the HexHead using the BMW-SCoil12E and CamHead using the kit BMW-SCoil12RT. So to answer your question-NO. Link to comment
Don_Eilenberger Posted January 4, 2016 Share Posted January 4, 2016 If just the rubber tip failed - these are usually separately replaceable, the trick is finding them. A trip to your local NAPA auto parts dealer might be productive - taking a coil with you so they can match it up. Link to comment
Edgar Posted January 4, 2016 Share Posted January 4, 2016 So a local dog was treating treating your bike as a fire hydrant? Link to comment
mistral Posted January 6, 2016 Author Share Posted January 6, 2016 Thanks for the input guys. Ron Link to comment
Don E Posted February 1, 2016 Share Posted February 1, 2016 Maybe someone can educate me on this. I recently upgraded from a 99RT to a 2011 RT. I haven't yet pulled the plugs but hope to replace before spring. Is the ignition coil now part of the plug wire? Do I need special care or tools to pull plug wires and replace the plugs? Link to comment
mistral Posted February 1, 2016 Author Share Posted February 1, 2016 Yes the the ignition coil is part of, or is your spark plug cap. There is a puller for it and you need to take care pulling them. I am not familiar with the 99. Ron Link to comment
