RPG Posted January 1, 2016 Share Posted January 1, 2016 Happy New Year everyone! In my winter downtime maintenance, I've decided to remove, inspect and if needed, rebuild the clutch slave cylinder on my '04 RT. (80k) Actually, I'm going to rebuild it anyway because I'm anal like that sometimes. [*]Where exactly should the weep hole be drilled? [*]Is it better to just cut out a notch at the bottom of the gasket for water and leaking fluid? [*]Where can I obtain a rebuild kit? BMW wants to sell the complete slave cylinder. thanks, RPG Link to comment
ltljohn Posted January 1, 2016 Share Posted January 1, 2016 Try looking at Beemerboneyard for the rebuild kit. Link to comment
Tri750 Posted January 1, 2016 Share Posted January 1, 2016 I've attempted the "rebuild kit" only once and it was a waste of money in this case. The bike had 70 something thousand miles and the cylinder was too far gone to take the kit. I'm sure others have had success, but on subsequent bikes the kit hasn't even been an option. We just got a new slave. Link to comment
Mark C Posted January 2, 2016 Share Posted January 2, 2016 I have one with 35k on it you can have for $35. Mark Link to comment
dirtrider Posted January 2, 2016 Share Posted January 2, 2016 Morning Rick Before looking into rebuild kits you might first remove the cylinder & clean inspect the push rod bearing. At 80 K there is a good chance that bearing is worn enough that you won't want to reuse that cylinder (bearing doesn't come in the rebuilt kits that I have seen) Also (carefully) inspect the cylinder wall & piston for wear as that will also nix any lasting repair. Personally, with all the work involved, I just install a new slave cylinder so I don't have to go in there again for a long time. Some drill the trans housing, some drill the cylinder --personally I just cut a slot in the gasket (it doesn't need to pass X-gallons per hour it just needs to allow as slight slow seep out)-- the 1200RT doesn't even use a gasket. Link to comment
PAS Posted January 2, 2016 Share Posted January 2, 2016 Even if using a new cylinder I would put a dab of grease into the bearing cavity and work it around and into the bearing. Link to comment
RPG Posted January 2, 2016 Author Share Posted January 2, 2016 Thanks guys, I've had no issues with anything clutch related but just figured with the mileage that I would have a look at it. RPG Link to comment
dirtrider Posted January 2, 2016 Share Posted January 2, 2016 Thanks guys, I've had no issues with anything clutch related but just figured with the mileage that I would have a look at it. Morning Rick What color is the fluid in the clutch handlebar reservoir? That will sometimes tell the story-- If the fluid is clear & clean looking then your slave is probably in decent shape but if the reservoir fluid is dark colored, or has little black particles floating in the fluid then your slave is probably going to cause you problems in the short future. Link to comment
RPG Posted January 2, 2016 Author Share Posted January 2, 2016 Thanks guys, I've had no issues with anything clutch related but just figured with the mileage that I would have a look at it. Morning Rick What color is the fluid in the clutch handlebar reservoir? That will sometimes tell the story-- If the fluid is clear & clean looking then your slave is probably in decent shape but if the reservoir fluid is dark colored, or has little black particles floating in the fluid then your slave is probably going to cause you problems in the short future. Good afternoon D.R., The fluid is always clean and clear as I change the fluid annually. At a minimum I'll remove the cylinder and check out the internal components, re-grease the bearing, etc. And the feed line from the master cylinder has some rust where it bolts into the slave cylinder. I'll need to clean that up. thanks as always, Rick Link to comment
