Bill Bass Posted December 17, 2015 Share Posted December 17, 2015 I have a 2002 r1150rt; after having my slave clutch cylinder replaced, the friction point is at around 90% of the way out, instead of around 60-70% where is was before. is there any way to adjust the friction point of the clutch lever? thanks in advance for any ideas. Link to comment
dirtrider Posted December 17, 2015 Share Posted December 17, 2015 Afternoon Bill Have you tried adjusting the little numbered wheel on the clutch lever? If that won't get you what you want then you either need to adjust yourself to the new friction point OR start modifying the clutch lever to master cylinder link. Link to comment
