John Ranalletta Posted December 7, 2015 Share Posted December 7, 2015 Bought a HF 20-ton press on sale + coupon. Added the HF air-over-hydraulic upgrade -sale+coupon. Added the SWAG Off Road HD finger brake (some assembly and welding required). SWAG configures product to fit into USPS boxes. Postman almost got a hernia and thought they were boxes of ammo. Bend video Link to comment
LJR Posted December 13, 2015 Share Posted December 13, 2015 Pretty cool😊 alpha tig Didn't know if you had seen this over at adv rider... I know I want one. Larry Link to comment
John Ranalletta Posted December 13, 2015 Author Share Posted December 13, 2015 AHP's get just as many kudos and knocks as other offshore machines. There's a guy, Mr. Tig, over at weld.com who takes offshore welders, tests them and reconfigures the accessories. Usually throws away the foot pedals and torches and substitutes good ones. He doesn't seem to have any AHP units around. Another Youtube guy, Kevin Caron, reviews AHP machines from time to time. Likely all these guys get free stuff so, buyer beware. http://weld.com/index.php/shop-weld-com https://www.youtube.com/channel/UCqT8zU8dHbswxqYcG60VPGQ I just finished the first stage of a new project...a tubing bender. Used my Everlast PP154, DC Tig on 3/16" wall 2"x2" tube. The #9 CK flex head torch and coil got hot, hot, hot. Need a #17 torch at least for bigger projects. But, mine is a multi function machine. Stick, AC/DC tig and 45 amp plasma cutter. If you buy a Tig machine, get at least 200 amps. I'm impressed with this one. http://weld.com/index.php/shop-weld-com/shop-weldcom/mr-tig-kits/mr.-tig-series-mt200-ac-dc-detail Link to comment
LJR Posted December 14, 2015 Share Posted December 14, 2015 You need to move closer to me Thanks for the info. Larry Link to comment
LikeBikes Posted December 14, 2015 Share Posted December 14, 2015 Pretty cool😊 alpha tig Didn't know if you had seen this over at adv rider... I know I want one. Larry I have a well equipped workshop and a lot of budget equipment. I have a Chinese MIG that cost £250/$420. Its physically big like a commercial set, Euro torch and has pulse, spot etc. I have had a lot of MIGs. Had my first in 1975. This one is the best, it is awesome. In 2 years never snagged the wire with a 10 foot torch using 0.6 mm wire, never cut out. I have bought a wire on gun torch for £50/$80 that plugs into the Euro connector to weld aluminium. Of course it will be no good on thin sheet but a TIG is no good on thicker stuff. Cheap Chinese Tig - I want one! Pete Link to comment
John Ranalletta Posted December 14, 2015 Author Share Posted December 14, 2015 I prefer TIG and even on thicker metals it can be used for the root pass which accounts for up to 75% of the strength of the weld. I'm not very practiced as is evident. Link to comment
JohnnyJ Posted December 14, 2015 Share Posted December 14, 2015 Added the SWAG Off Road HD finger brake (some assembly and welding required). SWAG Bend video I'm a big fan of SWAG. I have their Portaband Table, and will likely add their finger brake system to my small shop. Thanks for the post Johnny J Link to comment
John Ranalletta Posted December 14, 2015 Author Share Posted December 14, 2015 Johnny, I also have the portaband and use it daily. If you buy the accessory miter gauge add an 1/8" face to it because it extends beyond the blade which will chew it up. The saw is not self-aligning in the stand, so you have to play around with it to get a square cut. The challenge with the finger brake is its size in that the angle iron base is very deep. If you're bending thin sheet or aluminum for brackets and shelves, I like this easy-to-build setup as well. Link to comment
JohnnyJ Posted December 14, 2015 Share Posted December 14, 2015 John Good Information. I also appreciate the link to Kevin Caron. I'm taking welding classes and 3-d design at the local Junior College. I hope to someday create art like his. Johnny J Link to comment
John Ranalletta Posted December 14, 2015 Author Share Posted December 14, 2015 sign up at weld.com. kevin posts there in the general discussion/art section and seems always eager to answer questions. i'd like to have his shop. watch his vids on 3d printing. huge stuff that takes days to lay up. Link to comment
