Charging RT battery
macx
Hi
It's an 11 model bike with 60k miles & original battery.
Never had any battery problems, but now getting weak for
starting.
Have a gel cell charger. Plugged it into the power socket
on the left fairing below the radio controls.
It continues to blink red / charging even if I leave it
plugged in for a couple days.
I have an 04 also and the green / maintaining light comes on
after just a short time.
Am I plugging the charger into the right place?
I suspect the battery has finally bit the big one.
Am I right?
Thx
Afternoon macx
That depends on a couple of things--
Is your gel cell charger compatable for a CanBus Era bike?
If your charger isn't for a CanBus era bike then your power socket needs to be wired battery direct with it's own fuse.
You might try hooking your charger to the battery posts directly & if it then works properly you have your answer on the compatibility of your charger to your bike's power socket.
