RosBos Posted November 9, 2015 Share Posted November 9, 2015 This is what I get from GS911: 41795 Error in Calibration data for ESA Currently present YES Symptom Implausible signal or value Engine warning light (MIL) NO Frequency count 1 Logistic(Healing) count 40 Now, after reading few posts i have tried jumping the rear spring motor with 12V (my car battery) and IT DOES move up and down. Damping settings on display do change but long press of the ESA button does not yield any changes (yes, engine is running when I do it). What I have not tried and someone suggested on one of the posts is disconnecting the battery for half an hour. Would that reset the calibration in ZFE or something? So, the question is: is there anything else to be tried before taking to dealer for the software update and re-calibration. I do have GS911 available. Thanks AB Link to comment
Dann Posted November 9, 2015 Share Posted November 9, 2015 Did you try recalibrating the rear strut with the GS-911? Link to comment
RosBos Posted November 9, 2015 Author Share Posted November 9, 2015 Did you try recalibrating the rear strut with the GS-911? Did not find that option on GS911. Is there one? If yes please do explain. Link to comment
Dann Posted November 10, 2015 Share Posted November 10, 2015 Did you try recalibrating the rear strut with the GS-911? Did not find that option on GS911. Is there one? If yes please do explain. After selecting your bike, Go to: Central Vehicle Electronics. You will see an ESA Calibration. Only the rear can be calibrated ( The front is for the GS) Hope this helps Link to comment
RosBos Posted November 10, 2015 Author Share Posted November 10, 2015 Thanks Dann. Found it. I was using beta software and from some reason would not give me all the options available. After installing latest non-beta I was able to calibrate. Results after calibration: ZFE 41795: Error in Calibration data for ESA The fault is not present now. This problem occurred once. Logistic counter: 40 Symptom: Implausible signal or value. MIL set: No Fault code history: Odometer 92784.0 km Vehicle speed 0.00 km/h Battery voltage 12.00 V All settings are back, it toggles thru them and it keeps settings as it should. Almir Link to comment
Dann Posted November 16, 2015 Share Posted November 16, 2015 Thanks Dann. Found it. I was using beta software and from some reason would not give me all the options available. After installing latest non-beta I was able to calibrate. Results after calibration: ZFE 41795: Error in Calibration data for ESA The fault is not present now. This problem occurred once. Logistic counter: 40 Symptom: Implausible signal or value. MIL set: No Fault code history: Odometer 92784.0 km Vehicle speed 0.00 km/h Battery voltage 12.00 V All settings are back, it toggles thru them and it keeps settings as it should. Almir This is strange. I'm using the latest Beta software on my GS-911 WIFI and the option is there. I'm happy that you solved your issue though Link to comment
