Aram Posted October 9, 2015 Share Posted October 9, 2015 Excuse my questions, but I'm still new to working on BMWs. I pulled the oil filler collar (source of oil seepage) to clean it, and replace the o-ring. I see crud. not much, but still. Should I be concerned? Thanks! Link to comment
dirtrider Posted October 9, 2015 Share Posted October 9, 2015 Evening Aram Your picture doesn't show what the crud is but a little crud on bottom is not abnormal. If you are worried then just remove the valve cover to see if anything in there. Link to comment
Jim Moore Posted October 10, 2015 Share Posted October 10, 2015 Hey, looks like you got it out without too much damage. Good job. You're halfway there. I wouldn't worry about that stuff. You probably picked it up on the way out of the hole. Link to comment
