LeDucBmw Posted September 29, 2015 Share Posted September 29, 2015 Both cylinders got 120 on compression quick check. valve cover and gasket appear dry. oil was coming from that side. Can't see specifically where its coming from. Got a head gasket from BOB's. About to heat up exhaust studs to remove exhaust. Any idea's Link to comment
dirtrider Posted September 29, 2015 Share Posted September 29, 2015 Both cylinders got 120 on compression quick check. valve cover and gasket appear dry. oil was coming from that side. Can't see specifically where its coming from. Got a head gasket from BOB's. About to heat up exhaust studs to remove exhaust. Any idea's Evening LeDucBmw Yes, I would never pull a BMW cyl head off unless I was 100% sure that was the leak. Make sure your front fork seal isn't leaking & blowing back, also make sure your oil cooler or oil cooler hose isn't seeping & running back & down. Also check the cam chain tensioner seal for leaking & check the little cylinder bottom bolts for being tight. If the oil leak started after your last valve adjustment then make sure the little rubber donut around the spark plug well isn't leaking. Link to comment
beemerboy Posted September 30, 2015 Share Posted September 30, 2015 Both cylinders got 120 on compression quick check. valve cover and gasket appear dry. oil was coming from that side. Can't see specifically where its coming from. Got a head gasket from BOB's. About to heat up exhaust studs to remove exhaust. Any idea's Also check the cam chain tensioner seal for leaking.... I can speak from personal experience that an extra 1/4 turn of a socket wrench can solve what can be a big leak. Link to comment
kalali Posted October 1, 2015 Share Posted October 1, 2015 Sorry but are we supposed to guess your bike's model, year, mileage, etc.? Garbage in garbage out... Link to comment
mnTwin Posted October 1, 2015 Share Posted October 1, 2015 Sorry but are we supposed to guess your bike's model, year, mileage, etc.? Garbage in garbage out... Kalali, It's in the title of this thread, "96 rt 128,000..." Link to comment
kalali Posted October 2, 2015 Share Posted October 2, 2015 Sorry but are we supposed to guess your bike's model, year, mileage, etc.? Garbage in garbage out... Kalali, It's in the title of this thread, "96 rt 128,000..." My bad.... sorry had a senior moment... Link to comment
