SKYGZR Posted September 26, 2015 Share Posted September 26, 2015 The RS has almost 70,000 on it now, and noticing that it is getting a bit "slow" in the grip return when letting off. (Doesn't "snap back", slowly returns.) Have tried some lube @ the top, yet hasn't really helped much. (It has the "lined" style cable.) I have checked, and even though it's a '96, it doesn't have a "bowden box"..just a cable that goes from the clutch side TB over to the throttle side...and the "choke"/fast idle cable is attached directly to the clutch side TB. So there are (3) cables attached to the clutch side TB..main from grip, Fast Idle, and "cross over", with (1)-"cross over" connected to the throttle side TB. Since it doesn't have the box, trying to determine what cables to order is confusing based on these diagrams: With Box NO Box ? So seeking any tips/tricks that might assist... Link to comment
dirtrider Posted September 26, 2015 Share Posted September 26, 2015 So there are (3) cables attached to the clutch side TB..main from grip, Fast Idle, and "cross over", with (1)-"cross over" connected to the throttle side TB. Since it doesn't have the box, trying to determine what cables to order is confusing based on these diagrams: Afternoon SKYGZR There are really only 2 cables attached to the clutch side (throttle cable & choke cable). One a single cable runs from the twist grip to the L/H throttle cam then that SAME cable keeps on going over the other side TB. You might try lubing the twist grip where it rides on the handle bar (they sometime drag there) & also check the end gap between the outer end of the twist grip & the bar end weight (they can also drag there). Link to comment
SKYGZR Posted September 26, 2015 Author Share Posted September 26, 2015 So the main throttle cable is actually (1) cable, yet w/ (2) attachment points on the TB..correct? I have tried "pulling back" the grip from the switch as well as the opposing end which has a throttle meister in leui of the standard bar end weight, and the TM is adjusted/working correctly. Suppose I could try removing the grip assm from the bar and lubing the inside (non heated grips), yet it kind of "feels" like a cable issue... Link to comment
dirtrider Posted September 26, 2015 Share Posted September 26, 2015 So the main throttle cable is actually (1) cable, yet w/ (2) attachment points on the TB..correct? Evening SKYGZR Yes, the cable wraps around the L/H TB cam then continues on to R/H side. Link to comment
dan cata Posted September 29, 2015 Share Posted September 29, 2015 Before ordering new cable, try to make the rubber cover on the R/H side handle, not to touch the brake reservoir or the vibration weight and see if that helps. It is also not a bad idea changing the cable given that the bike has that mileage, anyway. Dan. Link to comment
SKYGZR Posted September 30, 2015 Author Share Posted September 30, 2015 Both have been ruled out..see above post. Link to comment
awagnon Posted October 3, 2015 Share Posted October 3, 2015 Here is a good Tech Days seminar on oilhead throttle cables written by Ron Schmidt of Bavarian Motorcycle Works of Salt Lake City. Let me know if you have any trouble getting it. https://dl.dropboxusercontent.com/u/35468239/Throttle%20%20cable%20seminar.doc Al Link to comment
Tri750 Posted October 4, 2015 Share Posted October 4, 2015 Here is a good Tech Days seminar on oilhead throttle cables written by Ron Schmidt of Bavarian Motorcycle Works of Salt Lake City. Let me know if you have any trouble getting it. https://dl.dropboxusercontent.com/u/35468239/Throttle%20%20cable%20seminar.doc Al Are there any more tech articles done by Ron Schmidt out there ? Airhead or 259 preferred. Link to comment
awagnon Posted October 7, 2015 Share Posted October 7, 2015 He used to have an entire series on airheads and oilheads. For some reason, he took them down. You could try emailing his shop and seeing if he has a link to them. They are all excellent. Al http://bavarianmotorcycleworkshop.com/ Link to comment
