moshe_levy Posted September 26, 2015 Share Posted September 26, 2015 All- I scored a permanent mount Gerbings Dual Controller for the Wethead at a bargain price. This is the unit (though I purchased at the dealer which was running a sale): http://www.revzilla.com/motorcycle/gerbings-permanent-dual-temp-controller All of these years, I've used the non-fixed type controllers, plugged into a cable which connects directly to the battery. Usually, this cable has a 15-20A fuse. Something like this And I've always plugged my battery tender into the same cable when the bike was parked for extended periods. My question now is: Can I plug the tender into one of the two outlets on the permanent controller? -MKL Link to comment
dirtrider Posted September 26, 2015 Share Posted September 26, 2015 Morning MKL I sure wouldn't, backdriving the electronics probably isn't a good idea. I would just add a separate cable & socket like you have pictured. Link to comment
moshe_levy Posted September 26, 2015 Author Share Posted September 26, 2015 That's what I expected. The cable goes back through the controller on the permanent mount schematic (which I dug out AFTER I posted - doh!) so I totally agree with you as usual. OK thanks! -MKL Link to comment
elkroeger Posted September 27, 2015 Share Posted September 27, 2015 The other part of the answer is to leave the old pigtail in place, just for the charger... Link to comment
