zinhe Posted September 19, 2015 Share Posted September 19, 2015 Hi everybody first of all sorry for my poor english i write to you from south of France ! i have now a huge problem !! please help me !! my bike ( 1150 rt) made a sound like a diesel engine ( tactactactac) so i decided to change my left cam chain tensioner i have unbolt very smoothly the cam chain tensioner but there were no spring and no piston inside the hole i have tried to find something inside the hole with a little tool with a magnet and i have nothing ! So i decided to put a new piston in the hole with the new spring but it the two part went donw the hole impossible to find them !! my question is simple , is it possible to find them or they are already in the cam chain system and mean finaly that my engine is already dead ?? thanx in advance for your precious help ! best regards Link to comment
dirtrider Posted September 19, 2015 Share Posted September 19, 2015 Evening zinhe You never known where those parts will end up. Sometimes they will drop all the way down to the bottom of the crankcase & other times they will stay up in the cam chain guide or in that area. If the parts fall ALL the way to the bottom then probably no long term issues. On the other hand IF the parts end up in the cam chain, or bouncing off a connecting rod, then they could cause damage. I suggest to remove the valve cover then shine a bright light in the cam chain & chain guide area to see if you can spot them. Usually, when the tensioner parts easily fall into the crankcase there is something wrong with the chain guide (like broken or worn) that allows more space for the parts to fall down. If your chain guide looks OK then I would suggest that you install the 1200 hexhead L/H tensioner as that is a better tensioner & does stay together better. Link to comment
zinhe Posted September 19, 2015 Author Share Posted September 19, 2015 Evening dirtrider thanks you to help me again ! ( the first time was for my iabs ) . Just to be sure of your explanation : 1 i need to remove the valve covert to try to find them from there 2 if i can't find the parts you think i can let them inside the motor and put an another cam chain tensioner ? i have an another question : why the piston fell in the hole. normaly it must be stoped by something no ? Link to comment
Froggy Posted September 19, 2015 Share Posted September 19, 2015 I replaced mine several years ago and it was viewable, I used bent paper clip to remove. Hope everything works out. Link to comment
dirtrider Posted September 19, 2015 Share Posted September 19, 2015 Evening zinhe 1 i need to remove the valve covert to try to find them from there Yes, I sure would do that to see if I could find the parts if i can't find the parts you think i can let them inside the motor and put an another cam chain tensioner ? Maybe, if they fall ALL THE WAY down then probably not a problem. If they are caught up top then you might cause damage when starting the engine i have an another question : why the piston fell in the hole. normaly it must be stoped by something no ? Usually it is caused by the upper chain guide dropping down a little more than usual due to guide wear or broken guide. Link to comment
zinhe Posted September 20, 2015 Author Share Posted September 20, 2015 Evening dirtrider i have just finish the job , and i have seen a spring inside near the cam chain i think with a magnet i can be able to catch them But i have seen also a big mess : my upper rail chain is totaly broken i can see a piece of it in black platics is it a big job to change it ? Link to comment
dirtrider Posted September 20, 2015 Share Posted September 20, 2015 But i have seen also a big mess : my upper rail chain is totaly broken i can see a piece of it in black platics is it a big job to change it ? Yes, basically to do it right the engine has to come out of the bike & be split apart (a very big job) You need to get a service manual & read up on doing that job. There are some ways to cheat on installing those guide rails (too involved to go into here) but with all those pieces floating around in the engine, personally, I would want to remove the engine & & clean it out inside. You might be money ahead to install good used engine. Link to comment
flars Posted September 21, 2015 Share Posted September 21, 2015 Zinhe: look at to see how the cam chain guide/tensioner work together. Link to comment
