Magpie Posted August 27, 2015 Share Posted August 27, 2015 I have a 1996 R1100RT and there is an unused two wire plug near the rear aux socket. Green/white & Green/blue. Can any one tell me what this are for or should be connected to, as I connected it to the aux socket(Bad mistake) and now it wont start but turns over. No spark or fuel. Please help me. Link to comment
Stan Walker Posted August 27, 2015 Share Posted August 27, 2015 It connects to your fuel tank vent valve and is controlled by the main computer. Not a good thing to be plugging random cables into random plugs. But you know that. Now. I would check fuse #6 to start with, it provides power for this vent valve. It also powers your fuel pump, the injectors, the Oxygen sensor...... Hope this helps. Stan Link to comment
Magpie Posted August 28, 2015 Author Share Posted August 28, 2015 Thanks Stan; All Fuse check ok with test lamp. Link to comment
Magpie Posted August 28, 2015 Author Share Posted August 28, 2015 It wasnt connected to anything and the bike was running fine. There was nothing for it to connect to and the aux power socket was close and 'empty'so I connected it.Where should it go? Link to comment
Stan Walker Posted August 28, 2015 Share Posted August 28, 2015 Hopefully you checked both sides of each fuse. If it's not a fuse, it's possible you damaged the fuel pump relay. Counting from the right, it's relay number 4. That's one big relay then 3 small relays. I no longer have an R1100 so I can't check this but it may be the same type of relay as the horn relay number 3 just to the right of the fuel pump relay. If they have the same part number you can swap them to check them out. Link to comment
Stan Walker Posted August 28, 2015 Share Posted August 28, 2015 Where does it go It probably wasn't connected because someone in the past removed the charcoal canister that the US bikes originally had. The tank expansion valve connected the charcoal canister to the engine to purge any fuel vapors stored in it whenever the engine was running (hence the reason for using the fuel pump relay to power it). No charcoal canister, nothing to purge, valve not needed. Some wrenches leave it connected, some disconnect it. If you have a charcoal canister then it does need to be connected. Stan Link to comment
szurszewski Posted August 28, 2015 Share Posted August 28, 2015 Isn't there also a "loose" three pin connector that hangs out by the rear power port on the RT? My bike is not close at hand and I don't remember the color coding for the wiring, but I'd swear there was a loose connector back there...which of course I also can't remember the function of. I have disconnected my evap system, so maybe I'm just making this up Link to comment
Stan Walker Posted August 28, 2015 Share Posted August 28, 2015 Magpie listed wire colors for 2 pin connector, I went by that. Stan Link to comment
dirtrider Posted August 28, 2015 Share Posted August 28, 2015 Morning Magpie There is nothing in the aux socket that should cause fuse blowing or an issue (both aux plug pins are open & not connected to each other). Make sure your side stand is in UP position. Link to comment
kioolt Posted August 28, 2015 Share Posted August 28, 2015 dirtrider I was thinking the same thing about the aux plug. One thing I didn't know for sure is if the plug is internally grounded. I don't think so. What probably happened is after hooking up the wires the OP plugged something into the plug to test it. Depending on the resistance of that something might be the reason for the current problem even though it is now removed. Link to comment
Magpie Posted September 4, 2015 Author Share Posted September 4, 2015 Result - Motronic fried. Quote $2000 from shop. $200 - Ebay. Friend repair - 50c for two resistors . Priceless All running fine. Link to comment
Stan Walker Posted September 4, 2015 Share Posted September 4, 2015 Friend repair - 50c for two resistors . Priceless All running fine. I hope you bought your friend a beer, or two, or three!!!!! :clap: Link to comment
szurszewski Posted September 4, 2015 Share Posted September 4, 2015 That sounds like a great friend to have! Link to comment
