MyR1100RT Posted August 26, 2015 Share Posted August 26, 2015 Gents, The bigger tube on the left is the fuel tank overflow. I just noticed the other tube (probably 6mm). I dont know what it's for - it's long enough to reach back to the ABS unit on the back wheel. It comes straight down along side the fuel overflow tube. Just yesterday my ABS lights started flashing like they're supposed to when the system isn't working. I've charged my battery and will get a volt meter today or tomorrow so that I can trouble shoot the problem. I'm wondering if this tube might be part of the problem?? Thoughts? https://www.dropbox.com/s/tymjrnd7brgsucp/IMG_0886.JPG?dl=0 Link to comment
kioolt Posted August 27, 2015 Share Posted August 27, 2015 Could it be an old battery drain? Link to comment
Fraidycat Posted August 27, 2015 Share Posted August 27, 2015 Not an uncommon problem---but nothing to do with the tube This Post by one of our guys might help; http://ibmwr.org/r-tech/oilheads/ABS-II_low_voltage_modification/index.shtml Link to comment
mneblett Posted August 27, 2015 Share Posted August 27, 2015 Could it be an old battery drain? Right size for that. Link to comment
smiller Posted August 27, 2015 Share Posted August 27, 2015 There are two lines associated with the fuel tank. One is the tank vent (attached to the charcoal canister in US models, if it hasn't been removed) and the other is a water drain from the fuel filler area. There may also be a battery vent line depending on what type of battery is installed. Link to comment
PAS Posted August 27, 2015 Share Posted August 27, 2015 My 03 has at least 4 drain hoses, not pretty! Link to comment
greiffster Posted August 27, 2015 Share Posted August 27, 2015 My 03 has at least 4 drain hoses, not pretty! I don't think its more than 4. 2 fuel and 2 ABS. If you clip them together nicely and trim them all even, it doesn't look so bad. Link to comment
AndyS Posted August 27, 2015 Share Posted August 27, 2015 If fitted correctly they are invisible. I don't think its more than 4. 2 fuel and 2 ABS. If you clip them together nicely and trim them all even, it doesn't look so bad. It may be 5, because if a non Gel or AGM battery is fitted, there will be a battery breather pipe too. Link to comment
PAS Posted August 27, 2015 Share Posted August 27, 2015 If fitted correctly they are invisible. I don't think its more than 4. 2 fuel and 2 ABS. If you clip them together nicely and trim them all even, it doesn't look so bad. It may be 5, because if a non Gel or AGM battery is fitted, there will be a battery breather pipe too. +1 Link to comment
