rcklindave Posted August 12, 2015 Share Posted August 12, 2015 Hi On my 2015 RT, I'm trying to set up my nav 5 to listen to directions and play music to my sena 20s. I tried setting it up with a blue toothed headset and it worked but when I pair it to my Sena 20s and push the music button on the nav5 it tells me it needs a A2DP headset. I don't know how to get over this, has anyone here had that issue? Thanks in advance Dave Link to comment
hopz Posted August 13, 2015 Share Posted August 13, 2015 Yes I have... The best and maybe only solution short of buying a different headset is to invest the $10 bucks and buy a 16GB thumb drive. Load it up with your mp3's and plug it in... the right hand glove box. Forget trying to play music from the Nav 5. Link to comment
John Posted August 13, 2015 Share Posted August 13, 2015 Dave, the trick is to press the pairing button on the 20s, and within a couple of seconds of the LEDs start flashing, press the jog wheel to do a stereo pairing. I think you can only do one stereo pairing at a time. I pair mine to the bike and use a USB stick for my media. That's because BMW Australia are a bunch of tightarses, and only include a 2Gb card which: 1. Can't hold much music, and 2. Cannot be exchanged for a larger card because the AU maps are licenced only on that card. Link to comment
rcklindave Posted August 13, 2015 Author Share Posted August 13, 2015 Thanks guys i'll give it a shot tonight, I do not have a usb port since I didn't get the BMW audio option Dave Link to comment
Panhandle Chuck Posted August 13, 2015 Share Posted August 13, 2015 Thanks guys i'll give it a shot tonight, I do not have a usb port since I didn't get the BMW audio option Dave Without the audio option you may want to try this pairing option with music on phone. Not sure with the NAV V, but I'd try it. Link to comment
hopz Posted August 14, 2015 Share Posted August 14, 2015 Wait... no Audio system? That changes everything. A2DP pairing on my SMH10 set is one of three pairing methods. If your manual does not clarify I suggest calling Sena. You can get a straight answer on IF, then another on HOW. Good luck. Let us hear how it goes. Link to comment
gordiet Posted August 14, 2015 Share Posted August 14, 2015 That's what I did after fighting the pairing for a month. Everything works as designed now. Well worth the call. GT Link to comment
