AnotherLee Posted June 24, 2015 Share Posted June 24, 2015 Tools found in my BMW tool roll. What are they for? Link to comment
AndyS Posted June 24, 2015 Share Posted June 24, 2015 The one on the left looks like the tommy bar for the spark plug box spanner. The one on the right is an extension bar for use with the wheel nut spanner. is allows you to stand on the flat portion giving you half a chance of undoing the rear wheel nuts. These were standard items in the tool roll of the R1100/1150 bikes. I understand the tools supplied with the new R1200RTW consist of a small spanner and a screwdriver. Good luck with those 2 items! Link to comment
mneblett Posted June 24, 2015 Share Posted June 24, 2015 The one on the left works as an extension of the reversible screwdriver -- one end is crimped to fit into the screwdriver handle, and the other end is shaped to receive the screwdriver philips/straight shaft. Link to comment
AnotherLee Posted June 24, 2015 Author Share Posted June 24, 2015 Thanks, guys - much appreciated. Link to comment
Tri750 Posted June 25, 2015 Share Posted June 25, 2015 The red disc is an emergency buffet plate should you run into a buffet on the road. It can also be used as a flying disc if you run across a Border Collie at a rest stop or park. Caution, Border Collies cheat. Link to comment
lkraus Posted June 25, 2015 Share Posted June 25, 2015 The red disc is an emergency buffet plate should you run into a buffet on the road. It can also be used as a flying disc if you run across a Border Collie at a rest stop or park. Caution, Border Collies cheat. Nope. That is clearly the bottom of a 5 gallon bucket. Though I'll admit, it also is useful at a buffet. And Or for following a border collie... Link to comment
