Taylor 1983 Posted June 14, 2015 Share Posted June 14, 2015 Anyone know the general rule for length adjustment? Is this adjustment just on 2015's? (R1200RT) Link to comment
Alfred02 Posted June 14, 2015 Share Posted June 14, 2015 There is no rule. Just set it to it's lowest setting (longest out) if you want the least amount of mud/dirt thrown up onto the back. This rear fender add on could be purchased since the 2005 Hexhead as an option, and became standard as part of the purchase at least since the 2014 LC. Link to comment
Taylor 1983 Posted June 15, 2015 Author Share Posted June 15, 2015 Okay, will do and thanks! Link to comment
TrickLidz Posted June 26, 2015 Share Posted June 26, 2015 What's this adjustable fender you speak of? Link to comment
mneblett Posted June 26, 2015 Share Posted June 26, 2015 What's this adjustable fender you speak of? The lower half of the rear fender will telescope in/out of the upper half. There is a T25 Torx screw on the back (tire) side of the fender you can loosen if you cannot pull it down by hand. Link to comment
BarryBeemer Posted July 3, 2015 Share Posted July 3, 2015 Yep! Check that little bugger for tightness every once in a while. Just met a guy who said his screw backed out on a long ride and he lost the bottom half of the mud flap. Link to comment
