TrickLidz Posted May 30, 2015 Share Posted May 30, 2015 I'm going to swap the kit from my 06 to the 15, but I read that there's no way to lower the rear brake pedal. Anyone have any fixes? TIA Link to comment
hopz Posted May 30, 2015 Share Posted May 30, 2015 Well, IIRC there is a way to lower the brake pedal. Get down there and take a look. There may be a positioning bolt/stop nut thingy... True, the amount of movement may not be very much but it can be done. My '05 could be moved a little but it was not worth the trouble on my bike. My advice is to just to the swap and see what you are dealing with. I move my SM peg lowering blocks and never have a problem. Link to comment
AZRTRDR Posted June 4, 2015 Share Posted June 4, 2015 Didn't find a way on my 2015 but I sure like the leg room provided and I have adapted to the high brake pedal. Link to comment
ehc0720 Posted June 4, 2015 Share Posted June 4, 2015 Has anyone tried the Grenac Designs or the Verholen adjustable peg lowering kits? Link to comment
TrickLidz Posted June 6, 2015 Author Share Posted June 6, 2015 I swapped them out, moved the shift lever down, left the brake lever where it is...seems to be OK. Link to comment
