KBMWGT Posted May 10, 2015 Share Posted May 10, 2015 So I had a fall off stopped dismount which bent my clutch lever. Still useful but has a big curve. 2006 K1200 GT Is a clutch lever replaceable? Costs guess? Easy to install or need clutch bleeding and all? I'm off on a 2 week two up ride in June so i thought I'd check to see if I could fix it. Link to comment
pedro cerveza Posted May 11, 2015 Share Posted May 11, 2015 Is it the whole assembly or just the lever? I recently found one of the levers (only) that I removed from my 05 K1200S. I'm not doing anything with it. If the part number is the same and it's just the lever you need PM me. It's just taking up space here. I'd be happy to give it to you. Link to comment
