vector-er Posted May 3, 2015 Share Posted May 3, 2015 it's the third time that my windshied stop working i dont know if it is after washing it the dealer just reprogram it and it is ok after we have change the commodo once and it not the problem dou you have an idea thanks Link to comment
Brian Louw Posted May 4, 2015 Share Posted May 4, 2015 it's the third time that my windshied stop working i dont know if it is after washing it the dealer just reprogram it and it is ok after we have change the commodo once and it not the problem dou you have an idea thanks There is a 'recall' on the left and right switch clusters that could fix that. Some guys also have had a problem with the microswitch for the Nav cradle. When you say not working, what are the symptoms? Stuck up or down or..? What is a commodo? Link to comment
Angel Posted June 20, 2015 Share Posted June 20, 2015 it's the third time that my windshied stop working i dont know if it is after washing it the dealer just reprogram it and it is ok after we have change the commodo once and it not the problem dou you have an idea thanks +1 on the left side switch cluster recall. Take it to your dealer and let them replace the cluster. Start there. Link to comment
Mark Mayo Posted September 19, 2015 Share Posted September 19, 2015 They now work in rain, cold or heat. I had both replaced for free and BMW seems better at their switch problems than GM. Link to comment
