CWD Posted April 21, 2015 Share Posted April 21, 2015 Anyone out there replaced their front turn signals with LEDs? Your thoughts on the outcome? And does anyone know of an option to allow the turn signals to work as white running lights while not flashing a turn signal? I thought I saw this online a few months ago but can't find it anymore. If you've done this, please post a picture in the running condition. Link to comment
nldaniel Posted April 21, 2015 Share Posted April 21, 2015 Is this what you mean: http://www.motorradzubehoer-hornig.de/BMW-R-1100-1150-RT/Leds-Glaeser-Birnen/LED-Blinker-mit-Zulassung.html I've seen them once on a bike, looked rather good. Link to comment
dirtrider Posted April 21, 2015 Share Posted April 21, 2015 Morning CWD If using LED bulbs then you will probably need to use resistors to increase the circuit load enough to make them flash. (or find LED bulbs with resistors in them) As for adding white running lights-- If you put them in the T/S housings then the light output will be lens color or if clear lens's then bulb color. If you (drill holes) and add addition bulbs then you can have clear bulbs for running lights & orange for turn signals. But if you have orange lens's then the running lights will be orange. If you just add in new sockets & use dual filament bulbs then your running lights will be bulb color (clear lens), or lens color (tinted lens's). OR--if you just want to make your current T/S lights into T/S + running lights then look at the Kisan Signal Minder (RUNNING LIGHT OPTION): "By attaching two quick-connect wires included, you can convert ALL FOUR turn signals to running lights and establish a dual-channel system on your bike". Link to comment
Searl Posted April 22, 2015 Share Posted April 22, 2015 Have you looked up "Blinker Genie" They flip the light normally off to a normally on. Your signal lights will stay on and flash off. I have the LED's on the front with the driving lights on full time. They work well. Link to comment
CWD Posted April 22, 2015 Author Share Posted April 22, 2015 Have you looked up "Blinker Genie" They flip the light normally off to a normally on. Your signal lights will stay on and flash off. I have the LED's on the front with the driving lights on full time. They work well. Never heard of it. I just google the site, but I'm a little confused. Did you buy their product, PLUS some LED replacement lights, or just their product? And do you have a picture or video link of your bike with them installed? Thanks. Link to comment
Searl Posted April 22, 2015 Share Posted April 22, 2015 Two separate purchases. I originally put them on the back to get more visibility. Did a little more research and found that full time amber lights on the back were illegal, had to take them off. I can get you pictures next week, I am traveling in Mexico. The bike is in Canada. Link to comment
eddd Posted April 22, 2015 Share Posted April 22, 2015 Another option is to use TruFLEX Dual Converter from Custom Dynamics. Link Scroll to the bottom of the page. I've used these to change LED arrays into a combination tail/stoplight. Link to comment
SAAB93driver Posted April 23, 2015 Share Posted April 23, 2015 It's not LED but Run-n-Lites are the easy to hook up and not too expensive, could even put a kit together yourself if you wanted. Had them for years on R1150RS and my R1100RS prior. http://www.run-n-lites.com/AppGuide-Run-n-lites.html Link to comment
Frank B Posted May 4, 2015 Share Posted May 4, 2015 I've been looking at these for a LED turn signal conversion. 'Looks like a simple install. Has anyone had experience with them? http://dynamicmotorrad.com/ Link to comment
RocketJohn Posted May 4, 2015 Share Posted May 4, 2015 I've been looking at these for a LED turn signal conversion. 'Looks like a simple install. Has anyone had experience with them? http://dynamicmotorrad.com/ for oilheads? Link to comment
shorttimin Posted May 6, 2015 Share Posted May 6, 2015 I'll give the Hornig lights a thumbs up. They shipped from Germany really quickly, were a very easy install. The white LED strip is powered by tapping into the little "candle" bulb power line. On my 1100RT, the white running lights illuminate the road about ten feet out, about 90 degrees coverage on each side. Link to comment
