steve.foote Posted April 18, 2015 Share Posted April 18, 2015 I was one of the early flange replacers (pre recall) and was wondering if there is a different torque spec since the new flange is steel instead of aluminum. Anyone know? Perhaps it's the same as the current wethead rear wheel bolt torque since it's supposedly the same part? Is that still 60nm? Thanks in advance! Link to comment
dirtrider Posted April 18, 2015 Share Posted April 18, 2015 Afternoon Steve As far as I know it is the same as I have not seen any service bulletins saying differently. At least if you stray a bit on the high side you shouldn't crack the darn flange ears now. Link to comment
steve.foote Posted April 19, 2015 Author Share Posted April 19, 2015 Yeah, I'm confident they won't crack now. The dealer put quite a bit of torque on the bolts when they replaced the flange (way more than 60nm). I'm fine with the standard torque, but thought it was worth knowing if it had been changed. Link to comment
Jim VonBaden Posted April 19, 2015 Share Posted April 19, 2015 Same torque. If the dealer used more than 60Nm, they are screwing up! Jim Link to comment
dirtrider Posted April 19, 2015 Share Posted April 19, 2015 The dealer put quite a bit of torque on the bolts when they replaced the flange (way more than 60nm). I'm fine with the standard torque, but thought it was worth knowing if it had been changed. Morning Steve Torque to loosen is usually quite a bit higher than the torque that bolts were originally set to (especially tapered seat type bolts). In the auto industry we seldom use torque-to-loosen as any torque indicator, instead we use torque to tighten from where they are, but even that is pretty useless on tapered seat wheel bolts that have been run-in for a while. Link to comment
