Marc01 Posted March 28, 2015 Share Posted March 28, 2015 Hi, am replacing my brake lines on my 202 R1151RT in a few months. Was interested to kinow has anyone had any experience with Galfer brake lines or are Spiegler the ones to get? Or is there another brand to use? Thanks Marc Link to comment
mneblett Posted March 28, 2015 Share Posted March 28, 2015 I have not used Galfer, but have used Spiegler more than once, including on my 2004 R1150RT-P. *Very* happy with the Spiegler kits, in part because they include the clamp blocks that allow you to "clock" the rotation of the end fittings to get the lines to lay exactly "right." I do not look elsewhere. If you want Spiegler, Tom Cutter (Friend of the Marque honoree) at www.rubberchickenracinggarage.com is a good source. You can use my name, but he'll probably say "who??" Link to comment
The Rocketman Posted March 28, 2015 Share Posted March 28, 2015 +1 on Spiegler. Got a good deal at STG: http://www.sportbiketrackgear.com/spiegler/brake-line-kits/bmw Wish they made clutch lines too..... Link to comment
greiffster Posted March 28, 2015 Share Posted March 28, 2015 Marc, I just finished replacing mine about 2 months ago. I bought Spiegler direct from http://www.spieglerusa.com/contacts. A real nice German fellow took my order. They fit perfect. Link to comment
Tri750 Posted March 28, 2015 Share Posted March 28, 2015 Both are fine. I've sold and used Galfer for years. The Galfers don't require a special tool to "clock" if required. It's in the instructions. You hold the crimped end of the banjo with a pair of pliers, insert a Phillips screwdriver or punch in the eye of the banjo and twist to fit. They recommend only turning 1 direction, and only 1 full turn. It takes only a few seconds and over the years, I've never had a problem when it had to be done or clocking a line to suit bar risers or my preference. I believe the difference is Galfer standard lines use chrome steel banjos and Speigler uses alu. Link to comment
T.M. Roe Posted March 28, 2015 Share Posted March 28, 2015 Marc, I just finished replacing mine about 2 months ago. I bought Spiegler direct from http://www.spieglerusa.com/contacts. A real nice German fellow took my order. They fit perfect. I had the same experience. Ordered a custom set of lines for the Duc that were perfect. Worth every penny. Link to comment
Lincoln_Faller Posted March 28, 2015 Share Posted March 28, 2015 I just replaced the brake lines on my '01 1150GS with Galfers. Very easy job and no need to adjust the end fittings; they were fine right out of the box. I'll be using Galfers when I replace the brake lines on my '02 1150RT as well. So far as I can see the one advantage is that a set of Galfers can be had for as much as ~$60 less than Spieglers. For instance, see http://motorcycleparts2u.com/brk-kt-comp-r11oogs-abs-94-01-mp2u080452, where the price for an 1150RT set is $155.89. There are also Galfers offered on Ebay at something less of a discount from retail. To be clear, I have no connection with these or any other vendors. all best, Lincoln Link to comment
greiffster Posted March 28, 2015 Share Posted March 28, 2015 Both are fine. I've sold and used Galfer for years. The Galfers don't require a special tool to "clock" if required. It's in the instructions. You hold the crimped end of the banjo with a pair of pliers, insert a Phillips screwdriver or punch in the eye of the banjo and twist to fit. The Spiegler kit came with the "special" tool (molded chunk of plastic) to spin and align the banjos. Link to comment
lkchris Posted March 28, 2015 Share Posted March 28, 2015 +1 on Spiegler. Got a good deal at STG: http://www.sportbiketrackgear.com/spiegler/brake-line-kits/bmw Wish they made clutch lines too..... Have Spiegler clutch line on my R1100S Link to comment
philbytx Posted March 29, 2015 Share Posted March 29, 2015 +1 on Sport Bike Track gear.....good prices, great service! Link to comment
