Front brake rotors
Pat Buzzard
Pat Buzzard
I have the opportunity to replace my worn out front brake rotors with a set off a low mileage R bike that's being parted out. I just want to verify, what thickness to these rotors start at, and at what thickness are they considered unserviceable?
My Clymer manual states the thickness as 5.0 mm (.1969") standard and the service limit as 4.5 mm (.177"). Also says the min thick *should* be stamped on the disk. Maximum runout limit is .12 - .15 mm (0.0047 - 0.0059") (don't know why there is a range on the max runout, I thought it would be a single maximum value.)
FWIW the outside diameter is listed as 320 mm (12.589").
Regards,
Rick
Afternoon Rick
Max runout is kind of deceiving (.15mm) over the entire 360° disk sweep is not a big deal but (.10mm) R.O. measured on a 90° (1/4 turn) sweep is going to give braking issues. (it kind of boils down to how quickly it goes from low to high & back to low)
