bulletbill Posted March 20, 2015 Share Posted March 20, 2015 Check my oil just now for a ride tomorrow and the glass was solid white. I said wow my oil has gotten WATER in it????? Dropped the oil and it's fine. Anyone have their sight grass cloud over? Cause? fix without replacing it? Link to comment
Guest Kakugo Posted March 21, 2015 Share Posted March 21, 2015 I had it happen a few times in the past (not on the RT). I adopted a pragmatic approach: I ignored the whole thing. There's always bound to be a little moisture trapped inside the engine, especially if the bike has been laid up for the Winter or is used a lot for short trips. Best cure is to go for a long ride so as to allow the moisture to be vented from the engine. To check if your oil sight glass is leaking, clean the area around it throughly with a good quality detergent, go for a ride and then pass a clean white rag or shop towel around it. If there's no oil, it ain't leaking. Link to comment
