Handle bar risers for 1100RT and 1150RT
HH0
szurszewski
Hey Harold -
When I bought the set that's currently on my R1100RT (excellent purchase, by the way) from Southsound BMW up in Fife, the bag was labeled for both models.
josh
szurszewski
Was there enough room when you installed the risers or did you have to install new cables/hoses as well?
Mine worked with orignal cables.
Should work with original cables and hoses.
Check carefully for undue tension on anything when the handlebars are turned to full lock.
If the brake hose on the right is tight, you can release the top of the right fork tube from the steering head, pull the tube down and pass the hose to the rear of the fork tube. Also, you may have to release a cable tie or two in the region below the steering head to free up a little slack in the wire harnesses.
FWIW, I once stacked two sets of bar risers on an R12RT (not the same bike, but similar -- it uses the same risers as an R11RT/R1150RT) without having to change hoses.
