Emcee Posted February 24, 2015 Share Posted February 24, 2015 I have a fault on my K1200LT 2007 bike. The warning triangle lamp is on and the brake failure lamp flashes once a second when I turn on the ignition. I can also hear a pump whining / running. I have bought a GS-911 to interrogate the bike and the autoscan report tells me that there is the following error on the integral ABS: "17166 Internal control module error - Analogue value, front pressure sensor" Can anyone please offer any advice on what the error means? I can't find any reference on the web to this error code or possible solutions. Any help would be much appreciated. Link to comment
Guest Kakugo Posted February 24, 2015 Share Posted February 24, 2015 Sadly this sounds very much like a component failure in the iABS unit. Pressure sensors are notorious for going bad and specialized outfits such as Module Masters are having a very tough time sourcing the parts needed for a rebuild. If you are based in Europe you can try contacting Carmo Electronics in The Netherlands: they can fix BMW ABS units (both cars and bikes) and may be able to source the parts. Link to comment
Emcee Posted February 24, 2015 Author Share Posted February 24, 2015 Thanks for your comments. I will post an update once I have found the actual problem or solution. I would like to get some detailed information on the iABS but any information is very scarce. I am a very hands-on person and I would like to try to repair the problem myself but worst case I will take it to a local dealer if all else fails. Link to comment
Guest Kakugo Posted February 24, 2015 Share Posted February 24, 2015 ADV Rider has plenty of topics with detailed pictures and informations. The problem is not so much the repair itself as sourcing new sensors. Link to comment
