kryter Posted February 20, 2015 Share Posted February 20, 2015 purchased a license plate mounted LED supplemental stop light. The pig tail connecter is about 6 in long, this will be exposed to the elements. This is not the problem as a little scotchkote will make this water tight. trying to figure out where to run the control cable any advice would be appreciated. cheers btw 2003 1150rt Link to comment
elkroeger Posted February 20, 2015 Share Posted February 20, 2015 Don't you just run it up into the tail light and tap into the brake light wire? Or are you asking something else? Link to comment
