Selden Posted July 18, 2014 Share Posted July 18, 2014 I spotted this stuff at Home Depot today, and decided to take home a roll for "future needs." Rated -65°F to 500°F, so it should be quite useful for rewrapping deteriorating wiring harnesses. It's gotten good reviews from those who understand how to use a self-fusing sealing tape of this sort. Similar to Scotch 2242 Rubber Electrical Tape, except that it's made from silicone rubber, rather than ethylene propylene rubber, so it has a much higher maximum temperature rating. Link to comment
eddd Posted July 18, 2014 Share Posted July 18, 2014 For your intended use it should be fine, but the pictured repairs are fantasy. The lumberyard/hardware store back in Texas put out a counter display but removed it because so many people came back wanting a refund because the product was unable to stop leaks like those pictured. If you are using it on a non-pressurized pipe (think drain pipe) it would probably do the job. Link to comment
szurszewski Posted July 18, 2014 Share Posted July 18, 2014 For your intended use it should be fine, but the pictured repairs are fantasy. The lumberyard/hardware store back in Texas put out a counter display but removed it because so many people came back wanting a refund because the product was unable to stop leaks like those pictured. If you are using it on a non-pressurized pipe (think drain pipe) it would probably do the job. +1 I use it for various things with good results but have tried it a couple times on small leaks and it just moves the drip from the leaking spot to wherever you stop wrapping the tape; I guess that might be useful anyway Link to comment
Bud Posted July 19, 2014 Share Posted July 19, 2014 For your intended use it should be fine, but the pictured repairs are fantasy. The lumberyard/hardware store back in Texas put out a counter display but removed it because so many people came back wanting a refund because the product was unable to stop leaks like those pictured. If you are using it on a non-pressurized pipe (think drain pipe) it would probably do the job. I guess that's why the don't sell a lot of it in Holland????? Link to comment
