BFish Posted June 23, 2014 Share Posted June 23, 2014 Found one on ADvrider that has me interested. Fairly low miles (mid 20's). Any advice on this year? Does it have the final drive drain plug or does the until have to be dropped to change the FD oil?? Link to comment
Matts_12GS Posted June 23, 2014 Share Posted June 23, 2014 Brian, I think it has the drain plug. Also should have whizzy brakes unless it's a GSA. Feel free to give me a call if you have more questions on it. Link to comment
tallman Posted June 23, 2014 Share Posted June 23, 2014 I think you need production date. Realparts OEM The change was integrated into production 07/08 I think AFAI can recall. Good luck. Even if you have to drop the rear, not that big, and you can inspect and lube alxo. Best wishes. Link to comment
Chris K Posted June 23, 2014 Share Posted June 23, 2014 Brian, I have an '07 GS and you do have to drop the final drive to change the oil, but it most definitely does not have the whizzy brakes. Except for that idiotic fuel strip it has been reliable over the 67K miles that it has on it. Link to comment
JR356 Posted June 23, 2014 Share Posted June 23, 2014 Brian, I have an '07 GS and you do have to drop the final drive to change the oil, but it most definitely does not have the whizzy brakes. Except for that idiotic fuel strip it has been reliable over the 67K miles that it has on it.  At least there is now a 12 year warranty on the fuel strips.  JR356 Link to comment
Huzband Posted June 24, 2014 Share Posted June 24, 2014 FD Drain plugs on 1200's per Munich were not available till '08. My '07 GSA does not have one. Edit' And no whizzy brakes, which is a good thing. Link to comment
Marty Hill Posted June 24, 2014 Share Posted June 24, 2014 Hey Brian, I put 42k on my '07 with zero probs. Great bike. Sold to a friend on the board. Link to comment
tallman Posted June 24, 2014 Share Posted June 24, 2014 Danny, I believe some'07 GSA's did. That is why it may depend on production date. I think the OEM parts show production from before the year '08 with dran plugs but I really don't recall the time they changed models began showing up on the floor. (Which could vary greatly based on when a particualr dealer sold their GS/GSA floor models) It all works. Link to comment
Firefight911 Posted June 24, 2014 Share Posted June 24, 2014 Danny, I believe some'07 GSA's did. That is why it may depend on production date. I think the OEM parts show production from before the year '08 with dran plugs but I really don't recall the time they changed models began showing up on the floor. (Which could vary greatly based on when a particualr dealer sold their GS/GSA floor models) It all works. My '07 GS Adventure had a drain. No pumpkin drop drill like my '05 ST. Link to comment
Heck Posted June 24, 2014 Share Posted June 24, 2014 Mine has an April 07 build date- no drain plug on the bottom.. The up side is that it prods you to check the rear splines when you do the final drive service- every 12k. Link to comment
Huzband Posted June 25, 2014 Share Posted June 25, 2014 Mine has an April 07 build date- no drain plug on the bottom.. The up side is that it prods you to check the rear splines when you do the final drive service- every 12k. And makes you want to shoot someone whilst wrestling it back together. Namely the engineer that thought this was a good idea. Link to comment
BFish Posted June 25, 2014 Author Share Posted June 25, 2014 my exact point for asking the question. I'm a beancounter not a mechanic...never sleep in in Holiday Inn Express either. talking to the seller this am so i'll get the answer. Link to comment
Matts_12GS Posted June 25, 2014 Share Posted June 25, 2014 Mine has an April 07 build date- no drain plug on the bottom.. The up side is that it prods you to check the rear splines when you do the final drive service- every 12k. And makes you want to shoot someone whilst wrestling it back together. Namely the engineer that thought this was a good idea. It just takes a little patience to get it back together. Honestly, if you can do the valves on your RT, you can do this on YOUR NEW GS.. Important thing to remember Brian, don't ride it unless you intend to buy it... they get under your skin in a hurry. DAMHIK Link to comment
Marty Hill Posted June 25, 2014 Share Posted June 25, 2014 Brian, the '07 is a great bike. Put over 43k on mine with zero probs. I've dropped the rear drives about 25 times. It usually takes between 30 seconds and 2-3 minutes if it decides to fight you when going back together. You will love the GS as Matt says. Link to comment
BFish Posted June 25, 2014 Author Share Posted June 25, 2014 As usual all your info is very helpful. Will keep you posted. Link to comment
Heck Posted June 25, 2014 Share Posted June 25, 2014 Mine has an April 07 build date- no drain plug on the bottom.. The up side is that it prods you to check the rear splines when you do the final drive service- every 12k. And makes you want to shoot someone whilst wrestling it back together. Namely the engineer that thought this was a good idea. Link to comment
norah Posted July 2, 2014 Share Posted July 2, 2014 Great bike. Sold to a friend on the board. Yup- and he's still riding it and I bought an O7 as well to replace my RT. LOVE the bike. Link to comment
Matts_12GS Posted July 3, 2014 Share Posted July 3, 2014 As usual all your info is very helpful. Will keep you posted. Hey Brian, are you a GS owner yet? Link to comment
