fatbob Posted May 31, 2014 Share Posted May 31, 2014 I don't find the FD ratio for the new RT on the BMW site, or in Mags. Anybody know what it is? My GS is 2.91. I'd like longer legs on the bike. Link to comment
Troppo Posted May 31, 2014 Share Posted May 31, 2014 It is higher than the GS - not sure by how much though. Link to comment
lkraus Posted May 31, 2014 Share Posted May 31, 2014 EDIT: Bad info here! Corrected info below. 2006 ratios from my RepROM, 2010 from a Motorcyclist review, 2014 from the BMW press release: R1200RT gearing | Overall ratio 2006 2010 2014 |2006 2010 2014 Primary 1.824 1.737 1.65 | | 1st 2.277 2.375 2.438 |10.882 10.808 11.706 | 2nd 1.583 1.696 1.714 | | 3rd 1.259 1.296 1.296 | | 4th 1.033 1.065 1.059 | | 5th 0.903 0.939 0.943 | | 6th 0.805 0.848 0.848 |3.847 3.859 4.072 | Final 2.62 2.62 2.91 | Drive | Gear ratios given here in BMW Motorcycle Magazine for the 2013 GS are the same as the 2014 RT. Link to comment
AlanS. Posted May 31, 2014 Share Posted May 31, 2014 2.75 is right out of the 2014 Rider's Manual on page 157. Link to comment
lkraus Posted May 31, 2014 Share Posted May 31, 2014 I stand corrected. Also found 2.75 listed on some dealers' web sites ( http://www.bmwmotorcyclesofriverside.com/inventory/v1/2014/BMW/By-Body-Type/Motorcycle/Tour/R-1200-RT/Base-Riverside-California---1548211 ) Parts lists at RealOEM.com also seem to show the GS at 2.91 and the RT at 2.75. Seems odd that BMW would not verify the facts before publishing their press release. 2006 ratios from my RepROM, 2010 from a Motorcyclist review, 2014 from RealOEM.com: R1200RT gearing | Overall ratio 2006 2010 2014 |2006 2010 2014 Primary 1.824 1.737 1.65 | | 1st 2.277 2.375 2.438 |10.882 10.808 11.062 | 2nd 1.583 1.696 1.714 | | 3rd 1.259 1.296 1.296 | | 4th 1.033 1.065 1.059 | | 5th 0.903 0.939 0.943 | | 6th 0.805 0.848 0.848 |3.847 3.859 3.848 | Final 2.62 2.62 2.75 | Drive | Link to comment
dirtrider Posted May 31, 2014 Share Posted May 31, 2014 Afternoon fatbob I don't know if BMW is still doing it on the wetheads but on the hexheads/camheads the gear ratio was stamped on the bottom of the drive (on the bottom flat in the pivot bearing area) If found, just divide the smaller number into the larger number for gear ratio. Link to comment
strataj Posted May 31, 2014 Share Posted May 31, 2014 Alen S has it correct and DR knows the formular Primary transmission ratio 1.650 1st gear 2.438 (39:16 teeth) 2nd gear 1.714 (36:21 teeth) 3rd gear 1.296 (35:27 teeth) 4th gear 1.059 (36:34 teeth) 5th gear 0.943 (33:35 teeth) 6th gear 0.848 (28:33 teeth) Transmission output ratio 1.061 (35:33 teeth) Gear ratio of final drive 2.75 (33/12 teeth) Jay Link to comment
lkraus Posted May 31, 2014 Share Posted May 31, 2014 Alen S has it correct and DR knows the formular . . Transmission output ratio 1.061 (35:33 teeth) . . Jay I try to be accurate. Where are you finding "transmission output ratio"? Link to comment
fatbob Posted May 31, 2014 Author Share Posted May 31, 2014 Thanks fellows. That's about 6% over the GS. Link to comment
strataj Posted May 31, 2014 Share Posted May 31, 2014 Alen S has it correct and DR knows the formular . . Transmission output ratio 1.061 (35:33 teeth) . . Jay I try to be accurate. Where are you finding "transmission output ratio"? Sorry but I’m unable to revel my source I will say it’s from a BMW publication. Jay Link to comment
