AlanS. Posted May 5, 2014 Share Posted May 5, 2014 i just bought a 2014 R1200RT this weekend and it is great. This is my first BMW. Over the past 22 years I have mostly been on Hondas. Now that I have it I plan on doing most of the maintenance myself. I have ordered JVB's DVD but would also like to get the service manual and a wiring diagram. Anyone know the BMW parts number and/or where to get them? Thanks, Alan Link to comment
Canuck1953 Posted May 6, 2014 Share Posted May 6, 2014 Hi Alan, I don't have any of the info you requested but I'd appreciate your take on the DVD as I am thinking of purchasing it too. I think that Rusty a manager at Max BMW (Rusty Gill, Parts Manager rusty@maxbmw.com) might have the info you require. Regards, Gordon Link to comment
lkchris Posted May 6, 2014 Share Posted May 6, 2014 Yes, the "anyone" you seek is your dealer parts department. The wiring diagram will be of little use, as the system is CAN bus. https://en.wikipedia.org/wiki/CAN_bus Link to comment
lkraus Posted May 6, 2014 Share Posted May 6, 2014 The wiring diagram will be of little use, as the system is CAN bus. https://en.wikipedia.org/wiki/CAN_bus A wiring diagram is still useful. It could be more useful if BMW would publish information about the operation of the computers on one end of those wires, but CANBUS is not VOODOO. All the electrical components outside of the black boxes will still respond to standard electrical troubleshooting techniques. Unfortunately, BMW only provides the diagrams as a separate (expensive) DVD covering multiple models. Usually the Haynes book has a model specific diagram, but it may be a year or two before that becomes available. Link to comment
Corvallis Posted May 7, 2014 Share Posted May 7, 2014 BMW does not publish wiring diagrams, Been there, done that on the GTL. Even on their service DVD there was nothing. No color codes, nothing. Link to comment
lkraus Posted May 7, 2014 Share Posted May 7, 2014 That's not good... Found the part numbers for the older CDs up to 2008, but nothing newer than that. Link to comment
Guest Kakugo Posted May 7, 2014 Share Posted May 7, 2014 That's not good... Found the part numbers for the older CDs up to 2008, but nothing newer than that. BMW used to supply a DVD (called WDS) up to 2007-8 which included wiring diagrams for both cars and bikes. This superseded the previous ETM (Electronic Troubleshooting Manual) which was model specific and included wiring diagrams. I am aware of a Mini-specific WDS which covers models up to 2010 but nothing about bikes. Link to comment
AlanS. Posted May 9, 2014 Author Share Posted May 9, 2014 Thanks for the information. I have not had good luck with the local BMW parts guys as they are the same for Ducati parts. Usually I can find more information on the web than from those guys. Things I have found out so far are that http://www.beemerboneyard.com/ sells a filter kit with filter wrench for a good price. The wrench is a Lisle 54760 which is a 76mm with 14 flutes. Alan Link to comment
Canuck1953 Posted May 9, 2014 Share Posted May 9, 2014 Hi Alan, Here's what I found re: lisle tool (oil filter wrench): http://www.amazon.com/Lisle-61570-76mm-14-Flute-Wrench/dp/B00AKA6NUQ All the prices in Canada are so expensive. The castrol oil for the bike that can be purchased in the US at Amazon for about $7 and change (/quart) can only be purchased with a BMW label for about $18(/quart). Similarly the final drive oil that sells in the US for about $22/quart in the US sells in Canada for $38 plus taxes for the same quantity. It makes me mad that not only can we not purchase castrol labelled motorcycle oil 4T racing 5W40 in Canada unless it's labelled BMW but that it's so much more expensive for exactly the same thing. Oh well. Link to comment
AlanS. Posted May 9, 2014 Author Share Posted May 9, 2014 For oil I will probably just use Shell Rotella T6 which is 5w-40. Easy to find and fairly cheap. I have used it in many bikes over the years without any problems. My F150 seems to use alittle of it between oil changes but not much. Alan Link to comment
AlanS. Posted May 9, 2014 Author Share Posted May 9, 2014 For the rear end oil I bought Liqui Moly from beemerboneyard.com. http://www.beemerboneyard.com/lqmsgo1500ml.html They also have the crush washers for the rear end. They come in a set for R1200 hexheads and camheads so there are a few extra items that are not needed but for $2.75 it is probably worth it. http://www.beemerboneyard.com/fnltrnscws3.html Alan Link to comment
Canuck1953 Posted May 9, 2014 Share Posted May 9, 2014 Hi Alan, I thought that we had to use 5W40 JASO MA2 motorcycle oil as opposed to oil for cars ... any thoughts? Link to comment
AlanS. Posted May 10, 2014 Author Share Posted May 10, 2014 Rotella T6 is 5W40 API SL and JASO MA and other letters. The manual states 5W40 API SL / JASO MA2. While there are many opinions on oil I have had good luck with Rotella for the past ten years in cars, trucks, and motorcycles. From what I can tell the MA vs MA2 has to do with low phosphorous and sulfur to protect the cats. Alan Link to comment
AlanS. Posted May 10, 2014 Author Share Posted May 10, 2014 From a little more digging Rotella T6 is MA2. http://www.epc.shell.com/Docs/GPCDOC_Local_TDS_United_States_Shell_Rotella_T6_5W-40_%28CJ-4%29_%28en-US%29_TDS.pdf Alan Link to comment
Canuck1953 Posted May 10, 2014 Share Posted May 10, 2014 Thanks Alan for your research and the link! I am going out this afternoon to see if I can find the shell oil and if I can, I'll be using it! Many thanks! Gordon Link to comment
Beemafied Posted May 11, 2014 Share Posted May 11, 2014 This explains oil specifications pretty well: http://www.oilspecifications.org/articles/JASO_MA_JASO_MB.php Gotta keep the clutch and engine in mind now. - Mike Link to comment
Mile Hound Posted May 11, 2014 Share Posted May 11, 2014 On my 2014 R1200 RT Wet Head, if I change my oil rather than the dealer, how can I reset the service icon? Link to comment
Alfred02 Posted May 11, 2014 Share Posted May 11, 2014 You can't. There is nothing out there on the market (yet), that will do this for you. Link to comment
Mile Hound Posted May 11, 2014 Share Posted May 11, 2014 Thanks for the information. Have a great week. Link to comment
strataj Posted May 11, 2014 Share Posted May 11, 2014 On my 2014 R1200 RT Wet Head, if I change my oil rather than the dealer, how can I reset the service icon? As Alfed said not yet, you need to wait for the new GS911 http://www.hexcode.co.za/ I think they will sell a shit load. Jay Link to comment
ADulay Posted May 12, 2014 Share Posted May 12, 2014 Rotella T6 is 5W40 API SL and JASO MA and other letters. The manual states 5W40 API SL / JASO MA2. While there are many opinions on oil I have had good luck with Rotella for the past ten years in cars, trucks, and motorcycles. From what I can tell the MA vs MA2 has to do with low phosphorous and sulfur to protect the cats. Alan Alan, Thanks. You just saved me a ton of "searching" and all that. I'll have to do an oil change out on the road later this month and I've seen that Rotella T6 stuff in a lot of places. AD Link to comment
