Sign in to follow this
EffBee
OILHEAD: Hall Effect Sensor Repair/Replacement
eddd
The link provides sound information but some of the steps may be unnecessary or modified to make them easier. Since the sensors themselves rarely fail I will limit my comments to updating the wiring.
- If you make good scribe marks prior to removing the HES plate you can skip all the steps involved with timing. The scribe marks allow you to easily and accurately return the plate to the exact pre dis-assembly position.
- You can skip the step where you lock the flywheel. Putting the bike in first gear and holding the rear brake will allow you to remove and re-install/torque the bolt holding the lower pulley and timing ring/cup.
- You can get to the connector by sliding the fuel tank back, but you will find that the rubber hood cover the plug will be very stiff. Simply slice the hood open to allow easy access to the connector. The slit hood can be taped back together (clean it first) when the job is completed. You will also want to clip the tie wrap that holds the cable. This will make it much easier to disconnect the connector.
- Skip the steps where the pins are removed and reinserted. simply leave a small pigtail of wire attached to the pins. You can solder the new wire to the pigtails and tape or use shrink tubing to insulate the connections.
- Make the new cable a bit longer than the original. This will make it easier to snake the connector back into place and snap it into the female connector.
- The cable can be purchased by the foot from McMaster-Carr. Enter 8219K56 in the search box. The cable will be high temperature, 22 gauge, 4 wires with a shield. You could get by with 2 feet, but 3 feet will allow you to add the extra length previously mentioned. The longer cable also allows you to make a few practice cuts of the outer cable sheath and stripping the individual wires.
Edited by eddd
Share this post
Link to post
Share on other sites
EffBee
Good stuff, Eddd.
Share this post
Link to post
Bud
eddd,
I went to mcmaster and tried to order 3 feet but it only comes in 10 foot increments so min order is 10 feet.
Share this post
Link to post
Stan Walker
There is a box that says other. Check it and you can specify exact length.
Stan
Share this post
Link to post
Bud
Stan
THANK YOU Stan!!
Share this post
Link to post
Lowndes
The other option is to send your HES to GSAddict (one of the longtime beemer gurus on this forum) and let him rewire it with ALL the proper wire, fittings, connectors, shrink wrap (spaghetti), then test the completed unit and return it to you QUICKLY.
His email: arbcon@sunshinecoast.ca
I just got mine back and he does beautiful work. And Very reasonable, too.
pXhbQ0JrRKZS4liGvSKncGoVQSAIL9yx0FKUVWVA_pkfKJJlLINBNa8pw8jWtVENuto43LuB4jEYMDIBKTIOWYD9G_sHHRMSKNFKAGLGA-akp8YXS4f5m5P6tFvo_gmmwpS2epKW9oeN7n-KEB8NCw6P32p0cVKeRIv9WaWAkfCGcnne7fAnpEbFOwLgqts9bGp7H30HVTKz-crJWAE77ox1c2KHbs_erHv-24wxlKUfszdPb_zEXZII88PnPmaffBTw-0ys5X3azDnShrqZUESy-aaOojJeU6cyF-1Ww27TGacvuQ6XNP57en5RygEJqoiHLpMLFB9BBr-fiQUrknCx_55f0Y-p1wNdvlF6KXx7z3wF3Hw9AEljhg9jD5RXzh7oGzv6Th1z3P7MdTlE0W9Gv3XhQaHk2aWPQoLNVH2vA_c7stOppQ6l7QsBr6cH8grdy3oNcVBw6sLgSaLE_Ci3zzWMBlPjTSiApiw9KfMOO3EMnnxgdci1r_NP__MZFKHFuzumKPpaRwTp4wnRXSvTjD8u5oHbW9cjgWWEbbAYEHMa9bnz1OGscfPpawYOPz8OTAebH01EiYFudqoqlHC06LY6SdYV0QHDdx_Y3tRunOgb2btpkN9iltYDuQyEGOa5Vjh7kH-x3Ct0OXPVuFRaIyMslxmricpdPez1QA=w1103-h622-no?.jpg
qvi1apH2rFwIe0Ncn9yFD_Iv44UhiIndf0fvuWMLYiqe8ZzvDdYRBRPkPE1sMxXqOsCX8qoAL_ML5d6QP9PDAHlsbKGkU_686-gJL1aV9BHxSpUxLMSTtrmrUcHWHxu-icWuB4DGHRP6zg9QxVdMk3jQ8US008ZbGb8UVuvtYxBGO10nU178m8ERbE33MjjtyJ_oCv85lqhoLDKJeZ2Ds5ILXrctkwzS4PZComcWg1ohGoR2ymceG7nYY6lIT_wJ95zBXHD0LcAGGO02MoL8v6aCBu-KpHG0TqKUgpmAaZe_TvuObbwI_wfYR511kZ0-RnD-OVyQegegDRiZWCYTzwYPFxRhszsBMi-9LzGr16KnAOKMuiImsNImdrRzaDIbdoTM2WNeBwoskMnh99V6gcFeNBHEuu6Wh4sVRy5ga3iVD08InyCY4ePC957DfLklhc--1RPzsZaOLXe6ZXwwKDGg5X-SOK_QsQT8lj9CsSwtBkk_pJHs9QV2BAVTgxtRSXCEyxchDI4bkypmlHJuf_MlJwL00OWvzlEnldH0fva13ECUnP5KksXzhKqX3VO2oFH0ed2f3LcvhKCQ54CuKyMQICDPZHHuxLhZREDDl42NXxqlypT285BDEDPBO3z4gUOLVc_FTVHauHPfyWfj60fpZ_MVza2h1_BeWAG6-Q=w349-h620-no?.jpg
9ZZ0rEH2UMJHncd7mhK3I6NTrOucmVPNZ3m6-dsAEtwh-b7bX_cM6b9cVthlm7sMzKwxlbgO5X689KI8hUMmEZjGmzs57OmjrfHULRZ2VKWTaN4NkyKoXW9HtsaY6ZwlLydd20Llzy0uQ_eeMn3mQZTROkMubZwROAogLG2KMtZi_UF5fL4Stt_1Sh3M97qUewgvULeyrksotbCEDFoTrDZRi89nPz1QTPzc3M9sqV3w2BKL-l-J_s8pCOS0JZQ1HgEJazXxHqosnlyKi9kLvZRSpe4-Czl7MME1z323XV7-bzmFV_OaOlsK9xopLpj1hzoQvkaMJv56Ukerh9yknnbfE-K85dB766lhBm-1PT9V80ElRnGdFQ_0TxcQDoZJMKq-CSJ7edj_bU0yfA6zBhOYkhoGLio4bqQl5o2-zUifo_NwEQqMXcS1ti-bo84w-21iHf8_t6ZoeEKgfgD15LsiTa_NuPIQMBhmzCH9_sP5AvJ0W-6inYT5GfiXurqaOvwRyACaQSpOUKe_ONVaRTHuXvct7fxhP15wxuAzgA2Vhno3TL7VnHrWhu0Rm3Thk011AegcuL3TLs1gTwNtgr_GCYCQ1tjfsjsCtBkgoqb1X5PejOks40AlZ2zKA6MvujL2iACE6fwtWvGfNHDeFH-254aos3if_0KxU9hIdg=w349-h620-no?.jpg
Share this post
Link to post
Hotmop
It looks like McMaster-Carr has changed the product listing so the "other" length can now only be 15 feet or more.
The minimum stock length is 10' for $44.40 + tax/shipping.
GSAddict is quoting $110 tested and returned in 2 days.
Share this post
Link to post
eddd
The website order procedure seems to be a bit off. Go to their website, enter the item number, click on other, and put in any length you want. I just did a test order for 3' and 1' without problem. You can ignore the 15' requirement.
Share this post
Link to post
Alan Sykes
What a fascinating thread detailing a repair procedure that would be unnecessary if BMW had kept their wits about them when sourcing the cables for the HE sensor. Especially impressive is friend Hager's step-by-step PDF. Beautifully produced.
However, when my HE wiring loom starts to cook out and give trouble, I'll simply invest in GSAddict's expertise for one of his refurbished kits - at around fifty of our quid, plus FedEx - why torture yourself ?
AL on the southern Med coast.
Share this post
Link to post
eddd
No torture. Following the changes to the procedure makes this a pretty easy fix for anyone who has done any soldering. Even if you are new to soldered repairs, I'm sure you can find some good tutorials on YouTube. Practice a bit before you jump in on your HES, and you should be good to go.
Share this post
Link to post
