OlGeezer Posted January 7, 2014 Share Posted January 7, 2014 It's the cylinders that are liquid cooled, not the heads. Just askin' Link to comment
Roadwolf Posted January 7, 2014 Share Posted January 7, 2014 Figured it was easier because of: Oilheads Hexheads Camheads So continuing the tradition Wetheads Link to comment
Guest Kakugo Posted January 7, 2014 Share Posted January 7, 2014 This engine uses precision cooling, meaning only a very small part of the cylinder is liquid cooled... the bulk of cooling passages are "wrapped" between the top of the cylinder and the combustion chamber. Also the heads themselves are water cooled: there are passageways over the combustion chamber, between the exhaust and intake valves... so it qualifies as a Wethead. Link to comment
OlGeezer Posted January 7, 2014 Author Share Posted January 7, 2014 Figured it was easier because of: Oilheads Hexheads Camheads So continuing the tradition Wetheads You left out the original: Airheads Link to comment
mickeym3 Posted January 7, 2014 Share Posted January 7, 2014 Guarantee if you ride one you won't think there is any kinship with it's predecessors. Completely different power delivery. Can't wait to take a RTW out for a ride, may go ahead and put some $ down on one. Link to comment
EffBee Posted January 7, 2014 Share Posted January 7, 2014 Figured it was easier because of: Oilheads Hexheads Camheads So continuing the tradition Wetheads You left out the original: Airheads No we didn't. Have you talked to Wurty recently? Actually, there's avery good Airhead board elsewhere, and this board began with the Oilhead RT's and we've just used that as our starting point and moved forward. No discrimination against Airhead Beemers. I used to own an R90S and miss it terribly, and for a lot more reasons than its collectible value. It was easily the most relaxing ride I've ever swung a leg over. Link to comment
OlGeezer Posted January 8, 2014 Author Share Posted January 8, 2014 Figured it was easier because of: Oilheads Hexheads Camheads So continuing the tradition Wetheads You left out the original: Airheads No we didn't. Have you talked to Wurty recently? Actually, there's avery good Airhead board elsewhere, and this board began with the Oilhead RT's and we've just used that as our starting point and moved forward. No discrimination against Airhead Beemers. I used to own an R90S and miss it terribly, and for a lot more reasons than its collectible value. It was easily the most relaxing ride I've ever swung a leg over. I bet you don't miss the lack of power, lack of braking, lack of handling or lack of light. I'm also pretty sure you don't miss the rigorous maintenance schedule (spine lube every 10k miles, rebuilding carbs, etc). Link to comment
szurszewski Posted January 8, 2014 Share Posted January 8, 2014 Figured it was easier because of: Oilheads Hexheads Camheads So continuing the tradition Wetheads You left out the original: Airheads No we didn't. Have you talked to Wurty recently? Actually, there's avery good Airhead board elsewhere, and this board began with the Oilhead RT's and we've just used that as our starting point and moved forward. No discrimination against Airhead Beemers. I used to own an R90S and miss it terribly, and for a lot more reasons than its collectible value. It was easily the most relaxing ride I've ever swung a leg over. I thought he just meant you left it off your list of head designations - not that "you" left it off this forum. Link to comment
OlGeezer Posted January 8, 2014 Author Share Posted January 8, 2014 I thought he just meant you left it off your list of head designations - not that "you" left it off this forum. That's exactly what I meant. Link to comment
AndyS Posted January 8, 2014 Share Posted January 8, 2014 It's the cylinders that are liquid cooled, not the heads. Just askin' Hi OlGeezer. Just to clarify We nicknamed it WetHeads BECAUSE the heads ARE water cooled. It is localised cooling around the valve seats and spark plugs. The Cylinders are air cooled with just the oil and air transfer taking place through them. See at 1min 38sec in: http://www.youtube.com/watch?v=h1hMpgtE9aA Andy Link to comment
OlGeezer Posted January 9, 2014 Author Share Posted January 9, 2014 It's the cylinders that are liquid cooled, not the heads. Just askin' Hi OlGeezer. Just to clarify We nicknamed it WetHeads BECAUSE the heads ARE water cooled. It is localised cooling around the valve seats and spark plugs. The Cylinders are air cooled with just the oil and air transfer taking place through them. See at 1min 38sec in: http://www.youtube.com/watch?v=h1hMpgtE9aA Andy "We"? O.K. I get it. My mistake. It looked like the cylinder has a water jacket on it due to lack of fins and someone told me the heads weren't water cooled. I should have verified. For the record, I also took exception to the term "oilhead" since it's predecessor have heads which are cooled by oil as well as air. Link to comment
AndyS Posted January 9, 2014 Share Posted January 9, 2014 "We"...The Royal 'We', as in those that are happy with the term and use the term readily because we like some simple designation between models..Airheads, Oilheads, Hexheads, Camheads, Wetheads. Great and simple way to make distinctions. Link to comment
OlGeezer Posted January 9, 2014 Author Share Posted January 9, 2014 "We"...The Royal 'We', as in those that are happy with the term and use the term readily because we like some simple designation between models..Airheads, Oilheads, Hexheads, Camheads, Wetheads. Great and simple way to make distinctions. Well...O.K., but only Airheads, Hexheads and Camheads make sense. Link to comment
AndyS Posted January 9, 2014 Share Posted January 9, 2014 No, Wetheads makes perfect sense So too does Oilhead, as they have a dedicated oil cooling loop in the heads (for cooling not lubrication). Link to comment
Dave_zoom_zoom Posted January 10, 2014 Share Posted January 10, 2014 Andy Thanks for that youtube show. THAT WAS GREAT! Dave Link to comment
