John in NC Posted January 25, 2006 Share Posted January 25, 2006 Has anyone here done the circuit bleeds without using the MiniStan? $60 just seems too much for a plastic funnel and brake cap. Does the circuit pump fluid out too fast to fill manually instead of from the funnel? Thanks in advance for all your responses. Link to comment
OlGeezer Posted January 25, 2006 Share Posted January 25, 2006 Has anyone here done the circuit bleeds without using the MiniStan? $60 just seems too much for a plastic funnel and brake cap. Does the circuit pump fluid out too fast to fill manually instead of from the funnel? Thanks in advance for all your responses. I made my funnel based on: abs3_filling_adapter.pdf (sorry, I tried uploading this file, but the system won't take a pdf file - Google it) I recommend using some sort of funnel. Good luck, Bill Allen Link to comment
Ken H. Posted January 25, 2006 Share Posted January 25, 2006 Has anyone here done the circuit bleeds without using the MiniStan? $60 just seems too much for a plastic funnel and brake cap. Does the circuit pump fluid out too fast to fill manually instead of from the funnel? Thanks in advance for all your responses. The rate the wheel circuit pumps fluid out is dependent upon how hard you squeeze the lever/pedal during the process. With a gentle squeeze (recommended) the rate is quite slow. Still, the funnel insures you don't accidentally pump air into the system. A big no-no. Sure it's $60, and you can build your own. But the topper is around $46 from BMW so $60 for a pre-built one is quite reasonable. Especially given you are going to save its cost 2X or 3X on your very first bleed job over paying a dealer to do it. Besides it's fun! So my suggestion - Pony up the $$. Link to comment
GAF Posted January 25, 2006 Share Posted January 25, 2006 who do i talk to about getting a ministan---thanks Link to comment
Ken H. Posted January 25, 2006 Share Posted January 25, 2006 who do i talk to about getting a ministan---thanks http://www.diymoto.com/ Link to comment
Joe Frickin' Friday Posted January 25, 2006 Share Posted January 25, 2006 Sure it's $60, and you can build your own. But the topper is around $46 from BMW... What is the "topper?" Link to comment
Rob L Posted January 25, 2006 Share Posted January 25, 2006 Sure it's $60, and you can build your own. But the topper is around $46 from BMW... What is the "topper?" The topper is the stock cover for the master cylinder resevoir. You will receive 2 of them connected by the vent hoses and a Y connector. You can make one for your self and sell another (or give it away) Drill a hole through one of them to fit a small funnel (I used a Coleman lantern fill funnel) and epoxy the funnel in place. Works great Link to comment
Urban Surfer Posted January 25, 2006 Share Posted January 25, 2006 Buy the mini stan. You can see the fluid in it. And it will impress any one that knows nothing about wrenching. : Link to comment
ESokoloff Posted January 26, 2006 Share Posted January 26, 2006 Some good info here http://bmwsporttouring.com/ubbthreads/sh...true#Post627295 Link to comment
OlGeezer Posted January 26, 2006 Share Posted January 26, 2006 Sure it's $60, and you can build your own. But the topper is around $46 from BMW... What is the "topper?" The topper is the stock cover for the master cylinder resevoir. You will receive 2 of them connected by the vent hoses and a Y connector. You can make one for your self and sell another (or give it away) Drill a hole through one of them to fit a small funnel (I used a Coleman lantern fill funnel) and epoxy the funnel in place. Works great Neither point is true (in my case). The "topper" comes as a single and cost me $24.19+T. The part number I purchased is 90 88 6 342 541 (for 2002 and older). I understand the PN for 2003 and newer models is 34 51 7 677 998. I got the funnel from McMaster for $3.79+ shipping. Bill Link to comment
steve.foote Posted January 26, 2006 Share Posted January 26, 2006 Neither point is true (in my case). The "topper" comes as a single and cost me $24.19+T. The part number I purchased is 90 88 6 342 541 (for 2002 and older). I understand the PN for 2003 and newer models is 34 51 7 677 998. I got the funnel from McMaster for $3.79+ shipping. Bill, the 90 88 6 342 541 part only works for 2002 and early 2003 models. The 34 51 7 677 998 part works on all model years. Link to comment
Ken H. Posted January 26, 2006 Share Posted January 26, 2006 Neither point is true (in my case). The "topper" comes as a single and cost me $24.19+T. The part number I purchased is 90 88 6 342 541 (for 2002 and older). I understand the PN for 2003 and newer models is 34 51 7 677 998. I got the funnel from McMaster for $3.79+ shipping. Bill, the 90 88 6 342 541 part only works for 2002 and early 2003 models. The 34 51 7 677 998 part works on all model years. Have to agree with Steve on this one. See part #5 on this page - ABS The 998 part is the entire hose ass'y with two covers/toppers. Link to comment
OlGeezer Posted January 28, 2006 Share Posted January 28, 2006 Right. The single worked on mine (2002), although I understand the original poster has a 2004. If the topper is indeed $46, then the premade gizmo sounds like the right direction to go. Bill Neither point is true (in my case). The "topper" comes as a single and cost me $24.19+T. The part number I purchased is 90 88 6 342 541 (for 2002 and older). I understand the PN for 2003 and newer models is 34 51 7 677 998. I got the funnel from McMaster for $3.79+ shipping. Bill, the 90 88 6 342 541 part only works for 2002 and early 2003 models. The 34 51 7 677 998 part works on all model years. Have to agree with Steve on this one. See part #5 on this page - ABS The 998 part is the entire hose ass'y with two covers/toppers. Link to comment
