R1200XX HAL Sensor(s)?
Ken H.
Exploring our R1200GS today I pulled the timing belt cover. This engine does not have HAL sensors mounted behind the crankshaft pulley like the R11XX series. So is this device mounted a bit higher into the front of the block our crankshaft position sensor now? What looks like a tube or pipe going into the white piece is actually a set of rather well protected sealed wires.
Speculation?
Ken,
You're EGGZACKLY right. That is the new Inductive crank position sensor.
Tightening torque: 8Nm
Inductive crankshaft sensor to timing case cover, M 6 x 16
I believe there is also a camshaft speed sensor on the right cylinder.
Mick
