kinchy Posted July 13, 2013 Share Posted July 13, 2013 Unlike my RT that provided options for mounting a GPS the GT seems to offer few obvious alternatives for Ram mounting hardware. I would appreciate any photos/advice regarding what options I have. Thanks Link to comment
FLrider Posted July 14, 2013 Share Posted July 14, 2013 I use a suction cup mount attached to the inside of the windshield. It connects to the GPS mount via a ram arm. I forget who makes the suction mount but it works very well, no risk of it coming off. Puts it right in my sight line. Not the prettiest install but very functional. I'll try a get a picture of it tomorrow if I get a chance. Link to comment
kinchy Posted July 14, 2013 Author Share Posted July 14, 2013 Thanks, The picture would be a great help. Wayne Link to comment
tallman Posted July 14, 2013 Share Posted July 14, 2013 I use this from Touratech to mount this Link to comment
NCStephen Posted July 16, 2013 Share Posted July 16, 2013 I used a mount on the windshield upgrights from Hornig. Expensive but the results continue to be outstanding. Puts the GPS tucked under the edge of the shield and easily glanced at without a total removal of your eyes from road. I actually use the speedo on the GPS much easier than the bikes speedo. I also have a ram mount on the clutch cover that has a ball, and extension to another ball mount that I use for the camera. It works easily enough but I would not like the GPS there. Hope this helps! See pictures. NCS Link to comment
cabron Posted September 18, 2013 Share Posted September 18, 2013 I use the RAM mount plate that bolts to the Clutch resevoir Description: RAM Motorcycle Brake/Clutch Reservoir Cover Base with 1" Ball Centered Part Number: Material: Price: Cart: RAM-B-345U Powder Coated Marine Grade Aluminum $23.71 good luck Link to comment
BrianT Posted September 20, 2013 Share Posted September 20, 2013 I use the RAM mount plate that bolts to the Clutch resevoir Description: RAM Motorcycle Brake/Clutch Reservoir Cover Base with 1" Ball Centered Part Number: Material: Price: Cart: RAM-B-345U Powder Coated Marine Grade Aluminum $23.71 good luck This was what I used as well. Never had any problems with it. Link to comment
