taters Posted January 9, 2006 Share Posted January 9, 2006 i had the dealer install a shelf on my '04 rt. i put some velcro on it and i attached my radar detector to an adapter and plugged it into my accessory outlet. could i do the same to a gps 2730?put it on my shelf and just get an adapter and plug it into my other accessory outlet? thanks Link to comment
kioolt Posted January 9, 2006 Share Posted January 9, 2006 I had an RCU shelf on my 04RT and found that my 276C would shake to much for my liking. I removed the RCU shelf and installed a BMR shelf. It is a lot sturdier than the RCU. If you still want to try it I would suggest that you use Dual Lock instead of regular velcro. Dual Lock has a lot stronger holding power. Link to comment
Mainuh Posted January 9, 2006 Share Posted January 9, 2006 i had the dealer install a shelf on my '04 rt. i put some velcro on it and i attached my radar detector to an adapter and plugged it into my accessory outlet. could i do the same to a gps 2730?put it on my shelf and just get an adapter and plug it into my other accessory outlet? thanks I don't think I'd rely on velcro for the weight of the 2730. I'd get some kind of mount that will firmly hold it and attach the to your shelf. Link to comment
