Pananimal Posted January 4, 2006 Share Posted January 4, 2006 I have relpaced the O'ring twice in the oil cap but still get some oil leaking out. I "think" it happens more on days I ride a little harder like in the twisties. Is this normal? Is there a fix? Or do you just learn to live w/ it? Link to comment
bigboy Posted January 4, 2006 Share Posted January 4, 2006 hi if you have just replaced your filter did you use one with a valve in it , if not you may be making a little to much oil pressure., or have you slightly overfilled it only a longshot but you never know. Link to comment
Michael Fajans Posted January 4, 2006 Share Posted January 4, 2006 The plastic sleeve into which the oil cap screws also has an o-ring that could be the source of your leak. To replace that you need to remove the valve cover. Link to comment
Boffin Posted January 4, 2006 Share Posted January 4, 2006 I have relpaced the O'ring twice in the oil cap but still get some oil leaking out. I "think" it happens more on days I ride a little harder like in the twisties. Is this normal? Is there a fix? Or do you just learn to live w/ it? There is a tendency for the oil filler to leak. Changing the O ring helps, and some of the aftermarket 'secure' caps are beter in this respect. The plastic inner section of the filler plug can also leak a bit, it has its own o-ring part no 11 14 1 340 901, it may be worth swapping this part out as well. Cya, Andy . Link to comment
Stan Walker Posted January 4, 2006 Share Posted January 4, 2006 Some of the BMW caps still had a little flashing left on them that prevents the O-ring from seating correctly. Just scrape it off if it has it. Stan Link to comment
Bill_Walker Posted January 5, 2006 Share Posted January 5, 2006 some of the aftermarket 'secure' caps are beter in this respect. And some of them aren't. I installed one (I'm sorry I can't remember which brand, but I think I got it from Bob's), double checked my installation against the instructions, and went for a ride. "Hmm, what's that smell? Smells like burned oil. [looks down] Oh, and it's all over my boot and my pants, too!" I put the stocker back in and haven't had a problem with it. But my RT is an '04 dual-spark, so maybe the new bits make a difference. Or maybe I'm just an idiot and did have it installed wrong. Link to comment
BobFV1 Posted January 5, 2006 Share Posted January 5, 2006 It's pretty common for them to leak. I installed a moto-techniques aftermarket unit which replaces the cheap stock plastic cap and the plastic sleeve with finely machined steel pieces - an excellent mod! http://www.moto-techniques.com/bmw.htm Link to comment
AnRSguy Posted January 5, 2006 Share Posted January 5, 2006 When I bought my new (to me) '04 R1150RT, I noticed mine was leaking after the 400+ mile ride home. Cleaned it up and thought it was just loose. Next day, 200 mile ride, same thing. I finally discovered if I cleaned it REALLY well before reinstalling the cap, NO LEAK! Clean the o-ring really well until it's dry and give it another try. Just a thought. Link to comment
RickP Posted January 5, 2006 Share Posted January 5, 2006 Mine started leaking around 8K, both the inner threaded sleeve and outer cap were replaced under WARRANTY. No problems since. -RickP. Link to comment
DogGone Posted January 5, 2006 Share Posted January 5, 2006 Mine has always weeped a little. Just recently I noticed it getting much worse on long rides. Locsl service manager says TADT. I swear, the next time he tells me that he's gonna be able to open up a boot store in his ass. Damn, I forgot I'm supposed to be in my kinder/gentler phase. Well, I never said it would happen overnight. pete Link to comment
Pananimal Posted January 5, 2006 Author Share Posted January 5, 2006 Thanks guys. I will look into the different checks. I rode two days hard this week up in the twisties and had the little leak I was concerned about but today I did more mellow countryside riding and it did just fine(no leakage). Go figure! Link to comment
SnowDog Posted January 6, 2006 Share Posted January 6, 2006 I swear, the next time he tells me that he's gonna be able to open up a boot store in his ass. Link to comment
