OlGeezer Posted January 26, 2013 Share Posted January 26, 2013 I gave myself a pair of Santiago boots for Christmas. Now, I have trouble shifting. I had a similar problem with my KLR and DS boots. I had to get another shift lever for it (longer). Am I going to have to do the same for the GSA? Link to comment
kmac Posted January 27, 2013 Share Posted January 27, 2013 You just need to figure out the new feeling and then practice that. I do not know about your 1200 GSA, but I know on my RT there is an adjustment on the shifter. Then there is 2 positions on the pivot mount for the shift arm. I found I liked mine in the lower setting. I think the problem starts with any boot named after a city in Chile... Just a little jab at my Chilean wife. Link to comment
BMWRich58 Posted January 27, 2013 Share Posted January 27, 2013 I gave myself a pair of Santiago boots for Christmas. Now, I have trouble shifting. I had a similar problem with my KLR and DS boots. I had to get another shift lever for it (longer). Am I going to have to do the same for the GSA? Gear shift lever "toe" is adjustable....longer/shorter. Worked for me. Link to comment
OlGeezer Posted January 27, 2013 Author Share Posted January 27, 2013 Gear shift lever "toe" is adjustable....longer/shorter. Worked for me. I did not notice a longer/shorter adjustment. I will check that out. Thanks! Link to comment
OlGeezer Posted January 27, 2013 Author Share Posted January 27, 2013 I do not know about your 1200 GSA, but I know on my RT there is an adjustment on the shifter. Then there is 2 positions on the pivot mount for the shift arm. I found I liked mine in the lower setting. The problem with an up/down adjustment is that it usually bites you somewhere else, like trying to downshift while standing up. That might be my last resort, however. Thanks for the reply. Link to comment
kmac Posted January 28, 2013 Share Posted January 28, 2013 No problem Geezer. You need more seat time....lol...ride over the hill and come visit me while I recoup. You can see my "project" bike... Link to comment
Ken H. Posted January 28, 2013 Share Posted January 28, 2013 Not as easy as on the RT, but the position can be adjusted. Look for the threaded arm connecting to the tranny itself. The locking clip’s a rotate and lift out affair, but once you figure it out it’s easy. (Look on the parts diagram for clarity.) I think most times I’ve switch boot brands I’ve ended up tweaking mine a bit. Link to comment
OlGeezer Posted January 28, 2013 Author Share Posted January 28, 2013 Not as easy as on the RT, but the position can be adjusted. Look for the threaded arm connecting to the tranny itself. The locking clip’s a rotate and lift out affair, but once you figure it out it’s easy. (Look on the parts diagram for clarity.) I think most times I’ve switch boot brands I’ve ended up tweaking mine a bit. Rotating it up or down usually causes a problem somewhere else. I think I found the solution. Has anyone tried one of these? Link to comment
kmac Posted January 29, 2013 Share Posted January 29, 2013 Well there you go Geez. And that is ALOT cheaper than new boots...especially since you already popped on some high dollar new boots. You still need to ride over the hill and visit... Link to comment
AdventurePoser Posted April 22, 2013 Share Posted April 22, 2013 I gave myself a pair of Santiago boots for Christmas. Now, I have trouble shifting. I had a similar problem with my KLR and DS boots. I had to get another shift lever for it (longer). Am I going to have to do the same for the GSA? Yes, it's just you. Link to comment
OlGeezer Posted April 24, 2013 Author Share Posted April 24, 2013 I gave myself a pair of Santiago boots for Christmas. Now, I have trouble shifting. I had a similar problem with my KLR and DS boots. I had to get another shift lever for it (longer). Am I going to have to do the same for the GSA? Yes, it's just you. I was waiting for someone to say that! Update: I've gotten used to my Santiago boots! Link to comment
kmac Posted April 24, 2013 Share Posted April 24, 2013 Just a boot breakin period. Cool. Link to comment
