Mark Mayo Posted January 13, 2013 Share Posted January 13, 2013 At times I hear the ABS sound after releasing the hand brake. This stops after the bike is warmer and has been in use. I have been on long, long rides where it never happened. It is worst when cold and I need to move the bike around to wash it. 1. What could I do or have done to stop this? 2. Does this sound like something I should worry about more? Thanks Link to comment
dirtrider Posted January 13, 2013 Share Posted January 13, 2013 Afternoon Mark Are you sure the noise you hear is the ABS controller pump & not the electric fuel pump? If you are sure it is one of the ABS controller pumps that is staying on then you really need to address that. Could be a bad switch or a bent switch leaf, or a sticking master cylinders piston, or an adjustment issue, or even a slightly sticking lever or pedal. First, you need to determine if it (the pump staying on) is being caused by the front or rear lever/pedal. Then once the end is identified you need to determine what is sticking, broken, or misadjusted. Link to comment
