Brad Moores Posted January 13, 2013 Share Posted January 13, 2013 Three months ago my RT (2011) would not start. Problem was kill switch was overheated in sunlight. Now, in winter here in Florida same problem re-occurred. Got it started and then running down road bike just turned itself off. Now can't get it re-started. Suggestions??? Link to comment
Marty Hill Posted January 13, 2013 Share Posted January 13, 2013 Take it to the nearest dealer for wty repair. Link to comment
GRB60 Posted January 13, 2013 Share Posted January 13, 2013 Yes. Happens to many. New switch required. Link to comment
kgerry Posted February 8, 2013 Share Posted February 8, 2013 Yes. Happens to many. New switch required. happens to many? when you are flying down the highway the bike just shuts itself off?? Link to comment
bikebits Posted February 8, 2013 Share Posted February 8, 2013 The starter switch fails when exposed to high heat or direct sunlight. Press the button to start and nothing happens. When under way there is no problem. Direct sunlight expands the switch housing and the foil strips that make contact can't touch. In an emergency, pour cold water over the switch housing and the switch will work. It happened to me in August and the dealer replaced the switch under warranty. Later they called me and replaced it again (although working) with a new part number that is supposed to cure the problem. It is a well known issue that has been discussed on this board, BMWLT, BMWMOA etc. Link to comment
na1g Posted February 11, 2013 Share Posted February 11, 2013 Exposed to high heat or sunlight??? Good thing motorcycles are never subjected to those. Geez, I'm beginning to think BMW engineers have their heads... where the sun don't shine. pete Link to comment
racer7 Posted February 17, 2013 Share Posted February 17, 2013 You haven't figured out that German guys are quite happy to use you for beta testing of their stuff that hasn't seen adequate testing time in the real world where climates are moe extreme than Germany? Their development tesingt in North America is a couple quick runs and call it good, if any. There is no such thing as sustained hot weather in northern Europe- which is why a whole raft of Ger,man stuff routinely has problems like adhesives, some rubbers (still),electronics, some plastics, etc. Not as bas as old Brit rubber from the 50sthat always dry-rotted and cracked i US sunshine in about a year... BMW Motorad relies on is customers for developmet testing which is why a lot of us say year 3 of a new model is good time to think about it. The GErman car makers do enough North American testing to do a better job but not quite enough.. Link to comment
Martyn Posted February 17, 2013 Share Posted February 17, 2013 Exposed to high heat or sunlight??? Good thing motorcycles are never subjected to those. Geez, I'm beginning to think BMW engineers have their heads... where the sun don't shine. What is this high heat you talk of ? Not seen here for a few years, mores the pity. Link to comment
Runnor Posted February 18, 2013 Share Posted February 18, 2013 Is this kill switch issue also a problem on the 2010RT? My warranty runs out this June. John Link to comment
dirtrider Posted February 18, 2013 Share Posted February 18, 2013 Morning John There have been a few switch failures on the 2010 model. There has also been at least one switch pod change (supercede) since the 2010. Will yours fail?- no way of knowing. Can it fail?- sure. With all the problems BMW has been having with the switch assemblies on the 2010>up RT's, unless your dealer is a total money grabbing pocket stuffer, you will probably get some good will help should yours fail. Link to comment
bikebits Posted February 18, 2013 Share Posted February 18, 2013 Is this kill switch issue also a problem on the 2010RT? My warranty runs out this June. John The problem arose when the new switch clusters (with left side turn signal switch) went into use with the 2010 models. Link to comment
