dogslife Posted January 9, 2013 Share Posted January 9, 2013 I have a 1995 R1100 RSL with side cases, but without rear case or rack. I would like to add GIVI case and I understand I need to use the E183 mounting bracket, but since i don't have an existing rack I'm missing the two mounting points on the tail just above the light. Does anyone know where I can get these parts and how hard it is to install? Here is my current tail: Here is the Givi E183 diagram with the parts I need highlighted be an arrow: Thanks! Link to comment
SAAB93driver Posted January 9, 2013 Share Posted January 9, 2013 You need the luggage carrier bracket kit http://www.bmwmcchattanooga.com/products/BMW-Motorcycles/1992/Set-luggage-carrier/1055808/71602317609.html And you will need to cut slots in the tail piece or buy one with slots already cut in it. Link to comment
CVA-42 Posted January 10, 2013 Share Posted January 10, 2013 I installed one of these kits on my R1100RS at one time. I cut the slots with a Dremel and cutting wheel. I think the kit comes with a couple of small rubber "aprons" that fit around the two pieces that fit through the cowling so you have a little bit of flexibility when cutting the holes, but not much. A tidy looking installation. Link to comment
tallman Posted January 10, 2013 Share Posted January 10, 2013 Two types of tails were produced, drilled and undrilled. OEM If you look for a drilled tail section the part number is 52532325090 $319.78 according to that chart. Link to comment
