mneblett Posted December 16, 2012 Share Posted December 16, 2012 I've pulled the left cylinder to address an oil weep/grunge on the forward-facing edge of the cylinder base. When I pulled the cylinder, I was surprised to see only one hollow dowel in the two front oil passages (none in the upper passage). Should there be two hollow dowels at the front of the cylinder base? Link to comment
lkchris Posted December 16, 2012 Share Posted December 16, 2012 Illustrated parts breakdowns available here: http://www.realoem.com Link to comment
mneblett Posted December 17, 2012 Author Share Posted December 17, 2012 Thanks, Kent. I've also looked at the MaxBMW parts fiche, and it appears there should be two hollow dowels, one for each oil bore. Since I only had one, I was checking to see whether anyone else had only one -- of course, a missing dowel would provide a good reason for there to have been weeping in that area! Link to comment
