Highway41 Posted January 2, 2006 Share Posted January 2, 2006 When refueling, I have yet to find a position that is not awkward. Any you guys try to rotate the filler cap assembly 180? Bill Link to comment
GelStra Posted January 2, 2006 Share Posted January 2, 2006 Try this. GS Filler reversal Link to comment
Lawman Posted January 3, 2006 Share Posted January 3, 2006 Try this. GS Filler reversal Holy cow! You Beemer guys just amaze me with the trouble you are willing to go to to change some little bitty itsy thing that you think could improved upon..Don't get me wrong..I'm not knockin it..I wish I had the ability and confidence and desire to tackle this stuff like that You're definately a different breed though Link to comment
wilsons Posted January 3, 2006 Share Posted January 3, 2006 I gotta be honest here, I've never had any issues with it Link to comment
GelStra Posted January 3, 2006 Share Posted January 3, 2006 I've never had any issues with it I don't lose any sleep over it and thus haven't gone to the trouble of doing it. As long as I put the bike on the center stand while fueling, I'm OK. Before I found out about the Dremel surgery required, I did try simply flipping it. 'Course it didn't work....... Link to comment
wilsons Posted January 3, 2006 Share Posted January 3, 2006 Heck I dont even do that. I put it on the side stand to swip the card, get the pistol, hit da button, and lean it back up straight and filler up. Ya gotta stick the pistol so far down in the tank on the ST anyway, its hard to make a mess. ... damn that sounded bad. Link to comment
GelStra Posted January 3, 2006 Share Posted January 3, 2006 get the pistol, hit da button, and lean it back up straight and filler up Are ya robbin' the place or getting fuel?? Link to comment
wilsons Posted January 3, 2006 Share Posted January 3, 2006 hah, I wear a face mask sometimes, you be the judge Link to comment
Iron Al Posted January 3, 2006 Share Posted January 3, 2006 Well, I've never spilled a drop (yet) but I really like the idea of turning the gas cap around 180 degrees. I always thought it opened backwards anyway. Link to comment
David_S Posted January 3, 2006 Share Posted January 3, 2006 If it's any help I reversed mine on the 12GS and didn't modify anything. Just unbolted it and turned it and re-bolted it. Definitely makes fueling on the center stand easier for us 5' 10" folks. Link to comment
sardineone Posted January 3, 2006 Share Posted January 3, 2006 Shawn, At least you have a quick get-a-way machine! Link to comment
Highway41 Posted January 3, 2006 Author Share Posted January 3, 2006 Thanks. Was exactly what I was looking for and my Dremel doesn't need batteries. I do need something to do during the long cold winters here in South Georgia. Link to comment
wilsons Posted January 3, 2006 Share Posted January 3, 2006 At least you have a quick get-a-way machine! hahaha Link to comment
RonB Posted January 3, 2006 Share Posted January 3, 2006 Depending on how you refuel and the type of nozzle, pressure can be put on the cap. I didn't notice until it broke and fell off one day. Turning the cap around might make it easier to keep the nozzle and pollution collar away from the cap especially for us short folks. Link to comment
Boffin Posted January 4, 2006 Share Posted January 4, 2006 Just in case anyone is wondering why BMW have the cap open towards the rear of the machine, it is because European Union vehicle construction regulations require it. The reasoning is that if the cap opens during a crash impact, the rider will push it closed as they slide over it, rather than having the family jewels removed by the cap . Cya, Andy Link to comment
St0nkingByte Posted January 4, 2006 Share Posted January 4, 2006 I'm glad this thread came up because I've had a devil of a time putting gas in my new RT. I thought it was too stupid of a question to ask but whats the trick? I tried putting the nozzle all the way in, like a car, and ended up with gas pumping but at a very slow rate. I think it ticked off the pump somehow. I tried pulling it part way out and it pumped but I ended up splashing gas all over. I'm not exactly new to motorcycling but the tank on my other bike has an inlet more like a gas can and this RT has this fancy inlet that looks like a car's but doesn't seem to work like one! Link to comment
artig Posted January 4, 2006 Share Posted January 4, 2006 I don't know if the RT filler neck is similar to the GS, but I had similar problems on the GS. The first thing I did was to remove the rubber extension neck fitted to the bottom of the metal filler neck. This could be done by hooking a finger underneath it and pulling it out. The second thing was to drill a 5mm hole in the side of the metal filler neck. This allows air to escape through the hole without blowing fuel back up through the filler neck opening. This modification requires the filler neck to be unbolted and lifted up out of the tank. While doing the hole modification I also reversed the filler cap. This did require trimming the plastic so the filler cap would close. And one of the 3 rubber spacers around the filler neck had to be cut in half. Since performing these modifications I've had no problems with refuelling. Link to comment
Mainuh Posted January 4, 2006 Share Posted January 4, 2006 Just in case anyone is wondering why BMW have the cap open towards the rear of the machine, it is because European Union vehicle construction regulations require it. The reasoning is that if the cap opens during a crash impact, the rider will push it closed as they slide over it, rather than having the family jewels removed by the cap. Cya, Andy That makes sense now that you mention it Andy! I know that's something we need to be mindful of as we strap on accessories around the handlebars. On a ride last summer I had my GPS and a video camera RAM mounted to the handlebars and an off duty motor officer riding with us mentioned the effects an abrupt stop might have on my continued capacity to participate in another fun hobby... It got me thinking about at least being more careful how and where I position that type of stuff. Link to comment
Jim VonBaden Posted January 5, 2006 Share Posted January 5, 2006 Just in case anyone is wondering why BMW have the cap open towards the rear of the machine, it is because European Union vehicle construction regulations require it. The reasoning is that if the cap opens during a crash impact, the rider will push it closed as they slide over it, rather than having the family jewels removed by the cap . Cya, Andy In that case my Tank Bag mount might be a bit painful! Jim Link to comment
