jimswms Posted December 28, 2005 Share Posted December 28, 2005 I'm looking for info and detailed pictures, if possible, of how you installed speakers and mic in a C2. Yep, I've seen the instructions on the autocom site, and, yep, I can be a bit thick. I can't figure out how they routed the wires so that the boom and the main thick wire come out the bottom. did they cut a hole in the lining? Also, where did you install the mic? It seems like it might be too long for easy placement? Any tips gratefully appreciated. cheers Link to comment
UberXY Posted December 28, 2005 Share Posted December 28, 2005 I tucked the mike boom in the slot where the chin strap comes out of the lining, velcro'ed in. I riveted the thick wire to the plastic trim on the bottom of the helmet using a wire clamp. Hope this helps. I found the Autocom instructions on the C2 to be not all that helpful. My setup works ok and looks neat, but even though I like the helmet a lot, I am looking around for a good helmet that is more Autocomm friendly, like perhaps a Nolan X-1002. Link to comment
