dixonduke Posted August 26, 2012 Posted August 26, 2012 I currently have the left side faring off while I do a radio removal of my new to me 2002 RT. I found what I assume is a vacuum hose with a 90 on it just laying loosely and not attached anywhere. Anybody recognize it? Where does it go?
kioolt Posted August 26, 2012 Posted August 26, 2012 Back when lead/acid batteries were used there was a overflow drain tube that looked like that.
mbelectric Posted August 26, 2012 Posted August 26, 2012 What he said. If your battery is a sealed unit, you don't need it , just tie wrap it away for use later if you need it on a vented lead acid battery. MB>
dixonduke Posted August 27, 2012 Author Posted August 27, 2012 Thanks for the reply's. I pulled the other fairing and chased the hose and can confirm that you two are exactly right. Cheers.
