ryan_a1982 Posted August 20, 2012 Posted August 20, 2012 Hello, I got on the bike this morning fired it up in neutral, kicked up the side stand and put into 1st gear and it died. I got off the bike and the side stand switch seems to be a little loose. I don't remember ever looking at it so I am not sure if there is a cap missing or if the switch should have a little play in it. Here is a photo. With the side stand up and the bike on the center stand, I pushed the switch down with my finger to seat it. Fired the bike up and it worked. I took the back roads to work so I wouldn't be on the freeway if anything happened. The bike started to surge a little bit, my guess is the switch lost some connection with vibrations. Anyone know if there is a cap or something missing that keeps the switch seated? Maybe I just need to buy a new switch. Bike Bandit has them for about $130, hopefully they are easy to install. I would prefer not having to replace the whole switch. Thanks for any advice, -Ryan
dirtrider Posted August 20, 2012 Posted August 20, 2012 Afternoon Ryan You are missing the little cir-clip that goes in the little slot just below the head of the pin that goes through the center of the switch.
bobmorris Posted August 20, 2012 Posted August 20, 2012 It is a 6mm cir-clip and very hard to find. Most local auto parts have "e" clips and a quarter inch e-clip works temporarily. At least that is what I am using. Bob
ryan_a1982 Posted August 20, 2012 Author Posted August 20, 2012 D.R. and Bob, Thanks for your reply. I looked at a diagram of the switch but it didn't have a view of all the individual parts. I will try to order the clip, Take Care!
dirtrider Posted August 20, 2012 Posted August 20, 2012 Afternoon Ryan Actually you need the small washer also. (clip & washer)
Guest Kakugo Posted August 20, 2012 Posted August 20, 2012 Washer is an ordinary M6x20; you can get it from hardware stores carrying metric or order it from BMW: 07119904427 The circlip/stopper ring is an ordinary M6x0,7 one. BMW part number is 07119903479. If they are asking more than a couple of dollars (a robbery, but OE bolts, nuts and sundries are bloody expensive regardless of brand) they must be made of gold.
